Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-30-2005, 11:14 PM   #1
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Default Summer blend MPG improvement ?
My fuel economy has mysteriously improved from a steady 19 MPG to high 21.x MPG.
The only thing I can think of is that my Sunoco has switched to the summer blend fuel (running 93octane). I fill up at the same station and same pump. And on average conditions have been the same for the past few weeks.
anyone else notice a bump up in fuel economy lately?
02_Forester is offline   Reply With Quote
Old 03-31-2005, 08:24 AM   #2
TurboBaja
Member#: 72618
2005 Baja Turbo
Garnet Pearl
my last tank was over 21 as well, usually I am between 19 and 20mpg. I did pay $2.26 a gallon for it, so maybe it was better gas
I've got an uppipe on the way, so that should help lower my mileage a bit
TurboBaja is offline   Reply With Quote
Old 03-31-2005, 07:28 PM   #3
su-be3
Member#: 78702
2004 BAJA Turbo
Frost Pearl White
Cool
Yup, I'm starting to notice it too. I use Mobil 93 as much as possible, and I am seeing 21 to 22 mpg now. Car seems to be responding a little better too.
I am paying $2.459 a gallon in my area. I hope they are wrong, but I don't see it getting any better for a while.
I keep track and order diesel fuel for my company, and this market is just so crazy right now! And the sad part is, there is NO reason for it to be this way.
Pure speculation is what it is!
If you haven't heard yet, some are saying the price of oil may spike out at $105.00 a barrel. So, that's somewhere in the $5.00 to $5.25 a gallon range! Be thankful you have a Subaru, and not a Hummer, right about now!
Keep it under 90, folks!
su-be3 is offline   Reply With Quote
Old 03-31-2005, 08:02 PM   #4
sir_wagon
Member#: 71549
The closer you are to 45 F to 65 F, the better the gas mileage. At low temps (<35 F), you also have heat losses affecting your gas mileage.
When it is hot outside (> 85), the heat differential between the motor (a thermodynamic heat engine), and the outside, starts to diminish, so you also start loosing efficiency.
sir_wagon is offline   Reply With Quote
Old 03-31-2005, 10:01 PM   #5
YooperBaja
Member#: 64311
2003 Baja
I noticed the first two posts have 2005 models. I have seen it posted several times, and experienced it with mine too, that the gas mileage increases after the motor is broke in.
For what is worth.... I had 27.7 mpg this weekend (389.0 miles on 13.97 gallons)driving 72 mph. I was loaded with a recliner chair and a bunch of other stuff in the back (chair stuck up over the roof by 6 inches). I also was loaded inside with all 4 members of my family and weekend luggage. Mine is not a turbo and it wasn't my best mileage (which was 30+ mpg), but I thought it was respectable considering the load.
My two cents worth..... and worth every penny of it!
YooperBaja is offline   Reply With Quote
Old 04-01-2005, 08:38 AM   #6
TurboBaja
Member#: 72618
2005 Baja Turbo
Garnet Pearl
Hi Yooper,
I've got 12k miles on mine, so I think it should be considered 'broken in'. The difference in my milage is probably just due to my driving style changes, I can't think of anything I am doing different, but there may be something. Also, I am due for an oil change. I don't know how much 'old' oil affects the Baja, but a long time ago in a state far, far away, I had a Mazda GLC and on 'new' oil I would get 36+ mpg and on 'old' (5000 mile) oil I would get 30 mpg. The Baja gets new oil every 3500 miles.
Old 04-01-2005, 01:10 PM   #7
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I did change my oil two weeks ago - Mobil 1 5/30. I didn't think it would play a role, but perhaps combined with warmer weather and summer blend fuel would account for the bump.
So many variables.
Old 04-01-2005, 11:19 PM   #8
mbaksic
Member#: 78280
2003 Baja Classic
Regatta Red/Silver
I just gassed up tonite and checked mileage. 25.2 this tank. Thats about where it will stay from now on unless I am on a trip. Best of 31.1 last summer, homeward bound from Yooperland back to SE Wisconsin. Mike
mbaksic is offline   Reply With Quote
Old 04-09-2005, 02:40 PM   #9
shibster
Member#: 73046
2003 Baja
Black/Silver
I got 26,000 miles on now and I consistently get 22-23 mpg on my '03 NA Baja. I change oil regularly at 4000 miles with mobil1, but it never makes a difference. Highway, city driving or a combination of the two give the same result. Does anyone else exhibit this pattern with their Baja??
shibster is offline   Reply With Quote
Old 04-11-2005, 10:47 PM   #10
jason.bogdan
Member#: 82812
2005 Baja Turbo
Monterey Gray
What would you say is "broke in"? I just hit 1500, my mpg has evend out a little, but the last 3 tanks have only been about 18 to the gallon ...
jason.bogdan is offline   Reply With Quote
Old 04-11-2005, 11:30 PM   #11
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Some motors take 20k miles to be completely "broke-in"
One of our members on Swedespeed.com has been getting regular oil analysis on his S60R and around the 21k mile oil change the analysis revealed stability. Here's a link to the report: http://www.s60r.net/car/blackstone/C32067.pdf
I sent my first oil change from the Baja to Blackstone. It will be interesting to see how it wears over the next 10-20k miles.
20% MPG improvement with a vehicle wrap? Dave Off-Topic 60 05-11-2009 05:38 PM
Warning! New Summer blend 93 octane. If you are tuned read!! Valhakar Engine Management & Tuning 99 08-19-2006 01:40 PM
MPG improve/worsen with age? Kokojura General Community 19 05-25-2006 12:16 PM
Tailgate down/ mpg improvement. Bed cover? dfritz Baja Forum 12 07-02-2005 11:38 AM
Uppipe MPG improvement? (long) scaryfastskier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 06-07-2002 09:40 PM
