Old 03-30-2005, 11:36 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default Wheel bearing/hub replacement cost?
I'm having my right rear wheel bearing replaced and found out the hub is also damaged now too. What should I be expecting to pay for the replacement of the two? I got a quote of $1200 total using new parts and $800 with used parts. Is this excessive? I had the same trusted mechanic do the left bearing alone a few months ago for a total cost of $250.
lotusTT is offline   Reply With Quote
Old 03-31-2005, 12:17 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...a new hub should only be ~$100...and replacing the hub is simple 'cuz ya gotta have it out of the knuckle, anyway to change bearings.....
....something wrong here.....if he charged $25o for a bearing, it should only be the cost of the hub more for the job.....and a bit for his head, mebbe....
Old 03-31-2005, 09:50 AM   #3
outbckspt96
Member#: 82717
just in parts alone it's 230.65 + tax....that's with brand new parts...new bearing...new hub...3 new oil seals...and a new axle nut....
outbckspt96 is offline   Reply With Quote
Old 04-02-2005, 05:46 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Thanks guys, apparently the hub was completely seized up and took the axle and some other stuff along with it. $400 for a used hub/axle assembly $100 for new bearing/seals and $250 in labor.
Old 04-03-2005, 02:42 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
....ouch....bad juju......well, ya know he's honest......and this is what happens when bearings go bad and seize.....
Old 04-19-2005, 05:37 AM   #6
JoeBloggz23
Member#: 4612
2014 Forester XT
Satin white pearl
Hey guys,
My right rear wheel bearing is acting up on me, and I will be replacing it soon. Anyone know the p/n for the rear wheel bearing? I looked on subaruparts and could not find it!
Eric
JoeBloggz23 is offline   Reply With Quote
Old 04-21-2005, 03:16 PM   #7
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Originally Posted by JoeBloggz23
Hey guys,
Eric
Here it is:
http://www.subaruparts.com/diag/?mod...category=281-1
$3.33 Nut-axle 28044AA000
$7.96 Oil seal-rear axle no.3 28015AA050
$7.72 Oil seal-rear axle no.1 28015AA100
$8.57 Oil seal-rear axle no.2 28015AA110
$56.77 Bearing-rear axle 28016AA030
If needed:
$117.51 Housing-rear axle right 28419FE000
$117.51 Housing-rear axle left 28419FE010
$4.53 Snap Ring 28035AA040
coolcougar is offline   Reply With Quote
Old 04-21-2005, 03:45 PM   #8
agterlik
Member#: 41626
SPB We make people
quit teh internet
I did not read the entire thread but why not go to a junk yard or find someone on nasioc with a trashed car and just get the hub used it will have everything already in it bearing wise and just stick it on there yourself its not hard to do. I did it in my own driveway with no clue of what I was doing.
agterlik is offline   Reply With Quote
Old 04-21-2005, 08:45 PM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
That's not a bad idea.
Tim Sanderson is offline   Reply With Quote
Old 05-11-2005, 03:17 AM   #10
JPX
Member#: 44504
1996 Legacy L Sedan
That's certainly a lot easier than tearing the rear end apart and carting around the hub to a machine shop to have the old bearing pressed out and the new one put in.
A seized bearing sucks - just welding your moving parts together and costs big bucks.
JPX is offline   Reply With Quote
Wheel bearing/hub problem.. Luizwrx Brakes, Steering & Suspension 6 06-04-2009 02:03 AM
Blown Rear Wheel Bearing / Hub luka Pre-2002 Factory Turbo Powertrain 11 05-07-2009 12:33 PM
02 wrx wheel bearings/ hub ASAP temallica1 Private 'Wanted' Classifieds 1 12-01-2008 04:36 PM
rear wheel bearing/hub help need'd. please GripGC8 Mid West Subaru Owners Club Forum -- MWSOC 17 01-13-2007 12:10 AM
So what exactly happens when your wheel bearings/hubs fail? root Brakes, Steering & Suspension 10 12-04-2004 03:22 PM
