Old 03-31-2005, 07:10 AM   #1
manman99
Member#: 51343
Default Cusco rear lsd or DCCD with Suretrac lsd Front and Rear
Hi All,
Like to find out with below configuration, which one will enter and exit corner faster ,
Configuration 1
a. Cusco rear lsd 1.5 way only, no lsd in front
Configuration 2
a. Dccd with front and rear STI suretrac lsd
Configuration 3
a. Dccd with front Helical lsd and rear STI mechnical lsd.
Thks
manman99 is offline   Reply With Quote
Old 03-31-2005, 08:12 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....ANY front lsd diff will be faster....and don't froget the center diff....
Old 03-31-2005, 09:37 AM   #3
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
I have configuration #3 in my JDM STi RA gearbox setup and I love it man
MK19_ is offline   Reply With Quote
Old 03-31-2005, 09:57 AM   #4
John Vanos
Member#: 49307
2006 Open Class STI
What will the car be used for?
John Vanos is offline   Reply With Quote
Old 03-31-2005, 12:20 PM   #5
moremaga
Member#: 12179
2002 WRX RA gears
Blk
If you only get one lsd, get a front. It will help you get on the gas sooner out of corners
moremaga is offline   Reply With Quote
Old 03-31-2005, 12:33 PM   #6
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
I have the 12kg center diff, helical front, STi mechanical rear. Heading to Summit Point this weekend for the first track test of this setup (RA gears, 4.44 final).
-Keith-
CTKAG is offline   Reply With Quote
Old 03-31-2005, 02:42 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The open front diff will be the best for corner entry. The best mid corner and exit setup is #3. Not a big fan of the suretrac diffs after having one in my 6MT. I'm replacing it with a Cusco 1-way front LSD.
Old 03-31-2005, 02:44 PM   #8
MK19_
Member#: 49148
Dogs are forever in
My front is the STi helical 1.5 way and the rear is the mechanical 1.5 way. I am very happy with this setup, albeit it is a lil noisy... Phil, any noise issues with yours? Not that it is incredibly loud, but being new to LSD's and all...
Old 03-31-2005, 02:49 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Not in the car yet. I have a Kaaz 1.5way rear and it's noisy.
Old 04-01-2005, 01:49 AM   #10
manman99
Member#: 51343
Thks for the reply...
If a wrx with only viscous coupling centre differential with no lsd front and rear at the moment And change to below configuration
- Cusco tarmac 35% / 65% centre differential
- and Cusco RS 1.5 way differential
A. How will this setup behave? Corner entry and exit?
B. will the Cusco RS 1.5 way nosiy? Is the noise is unbearable?
use the car for daily drive and occasional track day.
C. will this setup corner entry and exit faster or slower than below setup
setup 1 - Dccd with front Helical lsd and rear STI mechnical lsd
(Latest STI MY05).
setup 2 - Dccd with front and rear STI suretrac lsd
setup 3 - retain my wrx VC centre differential and put cusco front
and rear lsd.
D. must I put a front lsd for above confgiuration?
(Cusco tarmac 35% / 65% centre differential and Cusco RS 1.5 way
differential)
Thks
Old 04-01-2005, 04:52 AM   #11
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
(Latest STI MY05).
and rear lsd.
differential)
Thks
I asked Adam at Z1Performance if the Cusco Tarmac centre diff could be used in a WRX and he said only with a front LSD... in fact he sells a package of the Cusco Tarmac + Front LSD for 2199.
I guess the reason for this is that maybe the center diff is a type which cannot operate if one end is unloaded (and if you have an open front diff, as soon as one wheel is high-centered, that whole axle is "unloaded" and thus the center diff has no loading bias to operate the plates).
nhluhr is offline   Reply With Quote
Old 04-01-2005, 11:30 AM   #12
manman99
Member#: 51343
Hi Mustangkilla,
is the front STI helical or the Rear mechanical LSD that cause the noise?
is it like thud thud sound when you do cornering?
is it bearable?
Thks
Old 04-01-2005, 11:33 AM   #13
manman99
Member#: 51343
Hi dwx,
any reason why replace the suretrac lsd to the cusco 1 way?
what set up are you running in front and rear?
does the cusco 1 way has any sound like thud thud sound when doing
corners?
Thk
Old 04-01-2005, 11:39 AM   #14
MK19_
Member#: 49148
Dogs are forever in
Both LSD's make some noise. I get clunking and clacking at lower speeds when cornering- but it is bearable
d
Old 04-01-2005, 12:05 PM   #15
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Hi dwx,
corners?
Thk
I was either overpowering the suretrac last year or it wasn't reacting fast enough for my tastes. I'm hoping the Cusco LSD will work better in those regards. With the 6MT there aren't a whole lot of choices. I feel the Helical LSD in the 05 STI works better than the Suretrac, but it wasn't around back when I made the purchase. The Cusco uses clutch plates but shouldn't be as harsh as the Kaaz. It may still clunk at low speeds but probably nothing like the Kaaz, which is very noisy. I have a Kaaz 1.5 way rear LSD.
Old 04-01-2005, 12:13 PM   #16
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The tarmac gear is just an open differential, it's not a LSD at all. So if you are lifting a front wheel off the ground for some reason the car just won't go anywhere.
Old 04-01-2005, 02:06 PM   #17
moremaga
Member#: 12179
2002 WRX RA gears
Blk
d
I have a front Quaife lsd, no noise. That might be another option for you (manman99).
Old 04-01-2005, 06:18 PM   #18
Z1 Performance
Member#: 9327
the Quaife is quieter because its a helical..the Cuscos is a cluch type.
For the front, either style works very well - and as posted if you buy ANY aftermarket LSD, the front should be #1 on the list, as nothing provides as dramatic of a change in all aspects of the car.
For the rear, I cannot stand the helical styles at all for the simple fact that they rely on both wheels being on the ground.....since a WRX lifts the inside wheel under very tight/quick cornering, this can be a no no, and lead to understeer city. The Clutch types (both front and rear), while noisier, are also adjustable for lockup percentage, and some are adjustable for LSD action as well (1 to 1.5 way, or 1.5 to 2 way)
Adam
Z1 Performance is offline   Reply With Quote
Old 04-07-2005, 11:43 PM   #19
manman99
Member#: 51343
Hi All,
Thks for all your valuable inputs.
Old 04-08-2005, 12:49 AM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I personally would want this set up:
Cusco Tarmac center diff
Cusco 1 way front LSD
Cusco 1.5 way rear LSD
Reasons:
Front LSD: Traction on power out of corners and no LSD effect during deceleration for better steering response.
Rear LSD: Oversteer on power out of corners and some LSD effect for stability during deceleration into corners or mid-corner. This helps reduce the over-understeer transition when you're mid-corner and going WOT.
Center Tarmac Diff: Rear biased power is great!
I personally haven't has a LSD in my car, but I have put in a welded diff in the rear. The car totally changes in character. When I give it gas in a corner, the rear wants to come around. I HAVE done doughnuts with it in DRY pavement spinning like a top, not big circles. I've even done a doughnut without pulling the e-brake, I just simply floored it and the rear came around. I can do it easier if I pulled the e-brake to get the rear sliding first. But this is more of a spool rather than a LSD.
FuJi
FuJi K is offline   Reply With Quote
FS or FT: 04 sti brembo Front and Rear calipers and rotors. jbark1018 Suspension/Brakes/Handling 18 06-11-2011 03:18 PM
cusco zero 2e with econ, whiteline front and rear sway bars Sti_ck_IT Suspension/Brakes/Handling 17 11-22-2008 09:07 AM
CO: 07 R180 rear diff - 11k, will ship, 07 STi Front and Rear Axles GeneralTJI Drivetrain 6 06-11-2008 12:45 AM
So Cal: Feeler, JDM Pinks on 04 STi shocks, with Group N front and rear top hats krazy Suspension/Brakes/Handling 25 01-02-2008 04:30 PM
FS or WTT: 03 WRX Sedan Front and Rear Seats for STI front Seats/doorcards MoxaBall Interior/Dressup/Audio & Security 1 05-05-2007 03:01 PM
