Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-31-2005, 04:36 PM   #1
ndw1138
Member#: 32433
2005 STi V370
black
Default widest tire that can be run on a STi without rolling fendors?
I'm interested in going up to 235 which should be possible on 17X8.5? But my question is what's the widest tire that can go on a 04-05 STi without having to roll the fendors? Would appreciate any info..
thank you
nathan
ndw1138 is offline   Reply With Quote
Old 03-31-2005, 04:58 PM   #2
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
Well I run a 255/40-17 on a Rota 17x8 -48 offset with no problems. This is on a completely stock 05 STi. I am pretty sure they put a 275/40 on stock wheels on the 05 STi's for autocrossing as well, but I don't have concrete proof on that.
235/40s on a 17x8.5 wheel is not problem. I don't think 255/40 on the 8.5 would be either.
rankink is offline   Reply With Quote
Old 03-31-2005, 07:38 PM   #3
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
^at stock height
vtecTHIS is offline   Reply With Quote
Old 03-31-2005, 08:44 PM   #4
ndw1138
Member#: 32433
2005 STi V370
black
Originally Posted by vtecTHIS
^at stock height
I'll be putting on STi Coilovers (adjustable) before these wheels go on (track tire/wheels). I believe they lower the car about 3/4" by default. So should I assume this is too low for 245's?
And thank you both for the comments, really appreciated.
nathan
Old 03-31-2005, 09:03 PM   #5
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
There are a number of other concerns that you are ignoring. I have 17X8 wheels with the stock Bridgestones on them and they rub in the rear....reason why? The offset, these wheels, VOLK TE37s, have a +44 offset which makes for a much wider outside edge. Oddly though the outside edge of the wheel/tire only sits approx 15mm wider so it still suprises me that they rub but oh well
Good Luck
BLACK02WAGON is offline   Reply With Quote
Old 03-31-2005, 11:23 PM   #6
STI05
Member#: 76649
08 Z06
Victory Yellow
You should also consider camber, suspension height and tire geometry - some tires have larger radii on the edge than others - so they may be the same size in terms of model number but they may be different in terms of overall width at the location next to the fender. The stock tires have small radii - they're really wide for 225's. Pretty good tread width. This should be considered along with the offset of the wheels, wheel size, etc.
STI05 is offline   Reply With Quote
Old 03-31-2005, 11:49 PM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I am running 255/40R17 Azenis (wider than your average 255) on stock 17x8 BBS wheels with STI Pink springs. No problems at all. -1.9 camber in front, -1.8 camber in rear (camber achieved with camber bolts, NOT plates - this is worst case scenario for clearance between tires and struts). There is about a 1/2" gap between strut and tire in the rear and about 3/8" gap in the front.
nhluhr is offline   Reply With Quote
Old 03-31-2005, 11:59 PM   #8
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
^ am I seeing double?
Are there 2 STi's in your garage?
z is offline   Reply With Quote
Old 04-01-2005, 12:25 AM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yeah but one of them is a 2004 with S-03s - belongs to my roommate.
Old 04-01-2005, 01:46 PM   #10
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
2004 STi, pink springs, -1.7 camber rear, -2.8 front. 235/40-17 on 17x7.5 (OEM size) fits with lots of room to spare. 245/40-17 Kumho Ecsta V700 (R compound, wider than street tires) fits on 17x8.5 with no rubbing unless you're autocrossing with a full passenger load in the back seat. 225/45-17 Hoosier A3S04's on 17x8.5 (ET48 offset) require 4mm of spacers to keep away from the strut body, but otherwise fit with only minor rubbing.
Based on this and what I've read, 255/40-17 race tires on a 17x8.5 rim (one inch larger than stock) will not fit without rolling the rears on a 2004 STi. Perhaps aftermarket coilovers would give more interior room, 2005 STi's apparently have more room, and obviously going to a smaller rim gives you far more options (e.g. 17x7.5 OEM rim fits 255/40-17 Victoracers with plenty of room).
So, given the scope you requested: 2004 STi with 17x8.5 rims (what offset or type?), 235/40-17 tires shouldn't be a problem, 245/40-17 tires will probably fit but will likely require at least removing the fender protector trim, and my guess is that 255/40-17 tires will need minor rolling. As others have stated, the tire brand and geometry does matter as well.
I have a 2004 STi, now with coilovers, 17x8.5 rims, and just got my letter this morning from Tire Rack that my 255/40-17 Victoracers have shipped. So I'll be finding out in a week or two just how much work it is to make them fit.
WRX_Mundi is offline   Reply With Quote
Old 04-01-2005, 06:26 PM   #11
ndw1138
Member#: 32433
2005 STi V370
black
Thank you! much appreciated.
Interesting, why would the 05 have more room? The hub/bearing is really that much different in size? That's sorta suprising.. I actually do have a 05, and the wheels I'm considering are SSR comps at 17X8.5 with 235 or 245 45 side wall Bridgestone S03's. But as mentioned I will be dropping about 1/2-3/4", but the camber will stay rather neutral. I guess best bet is to install suspension and then measure it out as best as possible with current stock wheels..
again I appreciate any feedback..
nathan
Old 04-01-2005, 07:22 PM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
For a couple reasons really:
1) the 05STi rear fenders are already wider than the 04STi
2) the 05STi hubs are stiffer so there's less flex at the hub to let the wheel/tire to deflect inward (to rub struts) or outward (to rub fenders) on cornering.
Old 04-05-2005, 05:10 PM   #13
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
Thanks for the '05 answer, nluhr.
Here's a good reason why the specific tire and geometry matter. Click for larger image with readable text:
All tires unmounted. The two sets on the left are both the same rated size: 225/45-17. You can see there's a big difference in actual width (as well as weight and price, with the Michelin's actually being the most expensive since the Hoosiers went on sale). That extra inch of width can make a big difference in fitment. I'd hope this is exagerated given I'm comparing a street tire (albeit a pricey "ultra high performance all-season") to a Hoosier race tire, but I'm sure there is some variation in all examples.
In a few days I should be able to show RE070's mounted on 17x7.5, new A3S04's mounted on 17x7.5, and used A3S04's mounted on 17x8.5. All the same 225/45-17 size.
Old 04-06-2005, 04:22 PM   #14
silver04rs
Member#: 38825
^^ thats crazy!!! i kneww thre was a differencs but that is a lot
travis
silver04rs is offline   Reply With Quote
Old 04-06-2005, 04:55 PM   #15
MBPEJ20
Member#: 24360
2002 WRX Sedan
http://forums.nasioc.com/forums/showthread.php?t=746983
according to the pix in this thread, the hoosiers are 20mm wider each, than the ps2 and about the same height difference as your tires that are the same size.
weird.
MBPEJ20 is offline   Reply With Quote
Old 04-06-2005, 06:24 PM   #16
rankink
Member#: 12901
2005 STi/95 VX
What size are the Kumho victoracers on the far right? 255/40?
Old 04-06-2005, 06:46 PM   #17
jsalicru
Member#: 58031
click on the picture buddy....
As a SAFE assumption.. I will tell you this...
First off, its all about wheel offset here..
I run a 18x8.5 +48 offset... I also use 235/40s on these... I find that there is PLENTY of room in the front, on the OUTSIDE of the fender to run 255s faily easily... the inside I'm not so sure about. There was about a finger width between the rim and my TEINs when I put the wheel on by itself. In the rear, the clearance between the rim and the coilover is about the same... and here's a picture of the outside...
As you can kinda see here, there's plenty of room in the front.
I run -1.5 camber in the rear/-3.0 in the front.
My personal plan is to try 255s next and roll my rear fenders.. I might also get some spacers... maybe a 3mm or a 5mm to try in the front at least if there's a inner clearance issue.
jsalicru is offline   Reply With Quote
Old 04-07-2005, 01:13 AM   #18
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
Yes, the tires on the right are 255/40-17 Victoracers. I had the Hoosiers mounted today and they're quite a bit wider than the 235/40-17 RA-1's they replaced. The RA-1's have the gearing advantage though (not to mention usable lifetime and hence price).
jsalicru, nice photos. Here are mine with the 225/45-17 Hoosier A3S04 on Rota 17x7.5 SDR's (17x7.5 +48mm -- same as stock size but 5mm less offset), no spacers, coilovers set to 13" height hub-to-fender:
Lining up behind the Camaros with these tires in 335/35-17 size is intimidating. I'm surprised how much these fill the fender even with the 7.5" wheels. But it's not like these are tires you'd use every day.
Old 04-07-2005, 01:33 AM   #19
calworld
Member#: 5711
2004 STI
Hi, I am wondering what tire(brand/model) are you running? Also, if you don't mind, can you snap a few close-up shots of your tire on the rim. I want to see how 235 sits on 8.5 inch rim as I am debating whether to go 235/40 or 255/35 on my 8.5' rim
Thanks
Cal
calworld is offline   Reply With Quote
Old 04-08-2005, 07:03 PM   #20
shemoves
Member#: 80663
2005 STi
Without considering wheel gap...what is the widest tire that an 8" wide (STi) rim can hold?
shemoves is offline   Reply With Quote
Old 04-08-2005, 08:35 PM   #21
04STiguy
Member#: 36234
2005 WRX STi
CGM
I don't understand this. My '05 STI with stock wheels and tires has only 1/2" gaps between the strut body and the tire in the rear. Do you have wheels spacers?
Thanks
04STiguy is offline   Reply With Quote
Old 04-08-2005, 09:04 PM   #22
ej20love
Member#: 48520
2002 JDM WRX STi Ltd
PSM, Ducati
all depends on offset
ej20love is offline   Reply With Quote
Old 04-09-2005, 04:36 AM   #23
shemoves
Member#: 80663
2005 STi
just the wheels themselves...if they were removed from the car.
Old 04-09-2005, 04:59 AM   #24
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Thanks
nope. I would never run spacers. Perhaps my guess at the gap was off or perhaps yours is, but it is definitely "enough".
Old 04-09-2005, 10:27 AM   #25
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
I am running toyo ra-1's 255/40 all around with no fender rolling at all. Front wheels are 17x9 rears 17x8.5. I do have like 3 deg neg camber front 2.5 rear. But there is no rubbing issues. Car is lowered on zeal vunction v6 with 12k/10k setup.
drivrswntd is offline   Reply With Quote
Widest tire that can be fit on a 18x8 or 8.5 rim on a STi/WRX? gills Tire & Wheel 22 12-05-2015 10:11 AM
What's the widest tire that can be put on the 2.5i? SubieSubie Impreza Forum 20 11-20-2015 09:27 AM
most boost that can be run on deadbolt TD04. DLBWRXR AccessPort 12 09-03-2011 09:43 AM
What is a good dry grip tire that can be driven in cold temps? adrive43 Tire & Wheel 4 04-19-2009 05:23 PM
06 WRX, how much boost can be run on pump gas? riggs Engine Management & Tuning 9 11-23-2005 08:31 AM
