Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 03-31-2005, 06:27 PM   #1
97 subaru outbacker
Member#: 84225
1997 subaru outback
Default ticking issues
I have a 1997 subaru outback with a 2.5 liter in it. For a year or so now it has made this constant ticking noise coming from the engine. At start up it's most noticable, almost sounds like a squirrel in a running in a cage. I beleive that it's the lifters but not sure, it will continue the entire time I'm driving it, but eventually grow faint. Also it's almost always present when I accelerate after it has been warmed up. Is this a usual sound and the lifters are just loose or should I have it fixed, if its the lifters at all? Also I read something about the timing belt adjuster does anyone know how I check that?
97 subaru outbacker is offline   Reply With Quote
Old 03-31-2005, 08:49 PM   #2
Member#: 15773
2011 Impreza WRX
timing belt tensioner. no idea how to check
Jejunum is offline   Reply With Quote
Old 03-31-2005, 09:30 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
A mechanics stethascope. Start the car and listen to the front of the timing cover about 1 inch to the right of the crank pulley. While you're at it listen to the valve covers and each side of the block. You can also listen to the injectors.
Sears and carquest have them. I'm sure other places have them too. These can also help isolate bad idler bearings and water pump failures, alternator,p/s pump,and other rotating objects. Sometimes you can use it to find vacuum leaks/hissing.
It's a simple tool that really removes alot of guessing.
Get one.
Tim Sanderson is offline   Reply With Quote
Ticking noise / Starting issue... advice please. 93 Impreza SubyZ Normally Aspirated Powertrain 0 06-26-2007 08:17 PM
Tick, tick, tick, tick... So... While we're waiting for these boomers to retire... snvin Off-Topic 18 10-24-2006 03:09 PM
Burning oil / ticking turbo issue wrxnova1 Mid Atlantic Impreza Club -- MAIC 21 08-20-2006 10:56 PM
Tick tick tick tick tick tick.... Janq Off-Topic 62 11-11-2005 12:09 PM
Tick tick tick tick oldpreza Normally Aspirated Powertrain 10 05-13-2001 01:15 AM
