Welcome to the North American Subaru Impreza Owners Club Saturday March 7, 2015
Old 03-31-2005, 07:53 PM   #1
LEGGT
Member#: 81770
2005 Legacy GT Ltd
Obsidian Black
Default P0171 CEL - Due to tuning?
Hi,
Today I drove out to lunch, stopped to get some gas and my CEL came on.
I checked it at Autozone and it is a P0171 code.
I don't have a CAI, just the stock airbox. Do you think the error could be attributed to my dyno-tune/reflash last Friday? It is much warmer today and the Santa Anas are blowing. So I don't know if the outside temp or the wind conditions have anything to do with it. I disconnected and reconnected my MAF sensor. I also checked for loose vaccum lines but didn't find any.
So could this be a problem with the Tune and the temperature ?
Thanks,
~Will
LEGGT is offline   Reply With Quote
Old 03-31-2005, 11:25 PM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
it should be because the fuel cant run the AFR you want it to run. the injectors are only able to make a correction of about +-5%. so when they try to tun your AFR and cant do it for whatever reason (leak etc...) then the CEL comes on.
oh and search for a thread about that CEL. lots of good info there.
HonduHunter is online now   Reply With Quote
Utec able to remove cel due to tgv deletes?? wrxdragger UTEC 2 03-11-2013 04:43 PM
First CEL due to 3/16 Mod sonicwrx03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-31-2005 09:21 PM
CEL due to running lean due to cat back or removed silencer?? wrx_snobordr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-04-2004 12:22 AM
CEL due to system? NateDogg Car Audio, Video & Security 0 09-08-2002 05:26 AM
CEL due to engine sensor falling off = very hot turbo Snowphun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-21-2002 06:57 PM
