Old 03-31-2005, 08:03 PM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default Spark Plug Cheat Sheet..
People often email me asking what spark plugs to get before a dyno day, so I made a quick cheat sheet.
Comments?
-Jeff
PDXTuning is offline   Reply With Quote
Old 03-31-2005, 09:44 PM   #2
Rickyh
Member#: 40453
why no copper plugs? Is it the frequent changes?
Rickyh is offline   Reply With Quote
Old 03-31-2005, 09:49 PM   #3
Jejunum
Member#: 15773
2011 Impreza WRX
how about for RS's now
Jejunum is offline   Reply With Quote
Old 04-14-2005, 02:43 PM   #4
peterex
Member#: 27021
2015 WRX
bump...
peterex is offline   Reply With Quote
Old 04-14-2005, 05:22 PM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
PFR7G-G does not exist BTW. I went through three NGK "dealers" figuring this one out. The proper plug is PFR7B (NGK Part Number 4853) and I had to call NGK USA to get that info after MUCH talk with their NGK tech. This is a double platinum .030 gapped plug in one heat range colder than stock. Sparkplugs.com is about the only place to buy them and they are like $11.50 each.
Old 04-14-2005, 05:28 PM   #6
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
I've seen them for less, in case ya care...
BigJ04STi is offline   Reply With Quote
Old 04-14-2005, 05:46 PM   #7
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
My mistake.. The part I was refering to was PZFR7G-G.
http://www.sparkplugs.com/results_cross.asp?pid=4253
But, you are correct that you would want the 7B, as it is the correct projected length. I'll correct the sheet above as well.
At that price, why wouldn't everyone use the Iridium ones?
Cheers,
Jeff
sponaugle is offline   Reply With Quote
Old 04-15-2005, 02:30 AM   #8
odin1
Member#: 29362
2008 2008 sti
stage 2
sORRY, CAN'T READ THAT On MY MONITOR AND MY PRINTER IS ON THE FRITZ. cAN SOMEONE TELL ME THE CORRECT MANUFACTURER, PART NUMBER AND SOURCE FOR ONE HEAT RANGE COLDER PLUGS FOR A 2004 USDM sTI? THNX MUCH. OOps Cap lock stuck :-).
odin1 is offline   Reply With Quote
Old 04-15-2005, 12:16 PM   #9
WRXBob
Member#: 12455
02 WRX
I have been using BKR7E cooper plugs and it works very well, cheap and effective.
WRXBob is offline   Reply With Quote
Old 04-15-2005, 01:45 PM   #10
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Good info - thanks Jeff.
jblaine is offline   Reply With Quote
Old 04-15-2005, 02:02 PM   #11
Jimbo
Member#: 28809
2003 WRX Wagon
Platinum Silver Metallic
Ditto on the copper comments. I have been using BKR7E's on my conservative tune Stage III with absolutely no problems. Care to comment Jeff? Is the above table for agressive tuning?
Jimbo
Jimbo is offline   Reply With Quote
Old 04-15-2005, 02:03 PM   #12
Timdog1650
Member#: 45516
MY04 STi
Bump...why no copper?
Timdog1650 is offline   Reply With Quote
Old 04-15-2005, 02:22 PM   #13
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Jimbo
Yes, I'll modify the table to reflect that. The copper plugs work fine, but at much higher boost (especially in the 26-30psi range), I have had much better results with the small tip iridium ones. True the coppers are cheapers, but heh, it's a 20+k car with X$s in mods. Consider that Subaru from the factory switched to the Iridium tip plugs for the STI, and that is a pretty conservative tune. As well, you have to change the copper plugs much more often, and people often don't. I recommend something based on the likly outcome, and the iridium ones have the best IMHO.
Cheers,
Jeff
Old 04-15-2005, 04:35 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jeff, do you have any approximate power guidelines in terms of heat range? ie, 2x oem power, 1 range colder?
ken
Old 04-16-2005, 01:41 AM   #15
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
ken
Going one step colder depends on more than just power output. It also depends on how long you run the car at those higher temps. For example, you'll get the plug hotter during road racing, rather than drag racing. And what do you do if someone commutes in heavy traffic 98% of the time vs. someone that only takes thier car out for fun on the weekend? Your AFR and EGT's also play a part in picking the proper plug.
I'd recomend 1 step colder if you ever find yourself making a lot of 3rd gear pulls or if you're ever at WOT in the upper part of 4th, regardless of power output. Go 2 steps in the most extreme cases. For example, if you do several HPDE's a year and make a good bit more power than stock.
Pete
eastcoastbumps is offline   Reply With Quote
Old 04-16-2005, 09:12 AM   #16
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thanks for the input, pete.
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 702 02-09-2016 12:08 PM
WRX Trailer Hitch Wiring cheat sheet ANZAC_1915 Service & Maintenance 5 07-09-2015 12:37 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 04:45 PM
DRum's Newbie Cheat Sheet DrDRum Newbies & FAQs 24 10-24-2007 06:08 PM
alacrity024 to make Face to Name cheat sheets Georgethefierce Off-Topic 8 11-10-2004 12:40 PM
