Old 03-31-2005, 10:23 PM   #1
fat angel
Member#: 81630
Default stage 2.5 with mbc?
i've read a few threads , and by few i mean 3, where people have run a mbc with the ap. all where with the vf34 and where not hitting taget boost due to mods past the mapping. i know i am running rich and that iam not hitting target boost. iam past the suggestions for the map(fmic,pump,header). so has anyone else tried this little experiment? the results i have read (3) have been positive. anyone have any thoughts?
fat angel is offline   Reply With Quote
Old 03-31-2005, 10:26 PM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
i vote no
HonduHunter is offline   Reply With Quote
Old 03-31-2005, 10:27 PM   #3
fat angel
Member#: 81630
no thoughts? or haven't tried it? could you be a little bit more vague?
Old 03-31-2005, 10:38 PM   #4
blackie
Member#: 42979
03 wrx
blizzzack stage IV
I put one on mine the other day and it alowed me to hold full boost till redline and i also had a wideband 02 hooked up to monitor my afr's and they were fine, hitting around 10.8-11.1 at full boost and getting richer to 10.5 at redline. i have 03 wrx too if that makes a difference. im now experimenting with a restrictor in front of the mbc and setting the mbc lower so it will still taper the boost some in 4th and 5th gear. other than it worked out fine, just make sure and have a boost gauge before you think about trying it.
blackie is offline   Reply With Quote
Old 03-31-2005, 10:47 PM   #5
fat angel
Member#: 81630
well i have the boost gauge. i am currently running the vf34, fmic, walbro,and headers plus the requirements and more. i have noticed that i don't reach the target boost but that i do run very rich. i dont have a wb02 at the moment and thats the only part that discourages me. i think if i try the mbc set at 17 like you did blackie that i wont put myself in harms way. as far as the taper i dont think i would have too much to worry about considering my driving style. i dont do many redline pulls at all. i am looking at this as a temporary fix till i can get a map tuned with the protuner.
EJ20 stage 2.5 with oem STi injectors? watercooled Commercial ECU Reflashes 7 02-25-2007 09:25 AM
TURBOXS stage-2 Unichip with MBC bearbearbear Private 'For Sale' Classifieds 3 10-09-2005 05:07 AM
AccessPort Map available for Stage 2.5 with TMIC & Port/Polish VF34 The Modaholic Engine Management & Tuning 5 04-22-2005 11:24 PM
cobb stage 2.5 and mbc? fat angel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-08-2005 09:20 PM
Yet another Cobb stage 2.5 with VF30 impression.. WRXBob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-14-2005 11:27 AM
