Old 04-01-2005, 10:37 AM   #1
trex1200r
Member#: 56019
2004 Forester XT
Default AP Stage 2 Live Boost?
Flashed stage 2 yesterday, live boost only gets up to about 11 psi. Spikes to 10 or 11, then sinks down to about 9 and holds. Have an 04 Forester XT 4EAT. Cobb downpipe, SPT Catback. Probably have 60 miles on the car since I loaded the Stage 2 base map. 91 octane. Took a look under the hood yesterday, doesn't look like any hoses are off. Didn't remove any for the install anyway. Did end up pushing my intercooler around a bit trying to break loose a frozen bolt on the Turbo. Any thoughts?
trex1200r is offline   Reply With Quote
Old 04-01-2005, 01:13 PM   #2
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
Sounds like stock. Try selecting new map and load the realtime stage 2 map on .
If that don't help talk to cobb. it sound like the reflash never took
boost4life is offline   Reply With Quote
Old 04-01-2005, 09:23 PM   #3
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Make sure you get that reading at highway speeds. Not to sure how the EAT responds but I know you don't always see full boost until 3rd or 4th in the 5mt and that puts you upwards of 50-60 MPH.
phantomsr is offline   Reply With Quote
Old 04-02-2005, 02:06 PM   #4
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
I am running a stg.2 1.19-93 oct. map on my 02 WRX wagon. I am seeing 15-16+ psi boost on my Autometer. I cant look at the AP boost while I'm booting it, so I don't know if it's accurate. Did you flash a stg.2 base map? You really need to run an equal base to your realtime, or better. I did tighten up my wastegate adjustment one full turn, and that helped holding boost.
BIG GUN is offline   Reply With Quote
Old 04-02-2005, 03:11 PM   #5
jroberts
Member#: 34965
How do you get the AP to read live boost levels? Trying to find out.
jroberts is offline   Reply With Quote
Old 04-02-2005, 05:37 PM   #6
punk'd
Member#: 74342
05 STI
give it some time 2 to 300 miles the ecu is adjusting
punk'd is offline   Reply With Quote
Old 04-05-2005, 02:07 PM   #7
trex1200r
Member#: 56019
2004 Forester XT
I have loaded the base stage 2 91 octane map. Even reloaded stage 1, and then went back to stage 2 base map over a couple of day period. No real difference in performance that I can tell. Boost levels were the same with both maps. Have only tested first 3 gears of the auto tranny though. Never on the highway at times when you can open up and check the top end in fourth.
To read live boost, you just plug in your ap, set the function to live boost, and drive. Not the safest to hold the ap while putting the hammer down, so make sure you are in a no traffic area.
It has been a couple of 100 miles since my last reflash, doesn't seem to be learning any new tricks. Cobb asked me some questions today through email, I will post their answer if they have anything to add.
TREX
Old 04-11-2005, 02:29 PM   #8
trex1200r
Member#: 56019
2004 Forester XT
Well, low boost has been cured. Tightened waste gate adjustment arm 1.5 turns. Got rid of the fluttering noise, increased boost to hold 12 psi in 1st and 2nd on the Auto. Haven't been able to try a high speed run. No spiking, just strong consistent boost.
trex
Old 04-11-2005, 02:36 PM   #9
pezman04wrx
Member#: 66558
Kind of OT, but the fluttering noise you described ... Is it on spool up? ... I just installed my TBE yesterday, and I here a fluttering sound as well ... I had low boost, about 14.7lbs, but loaded the HWG map and the boost hits target now ... Could I just be experiencing this wastegate flutter as well? ... Guess I kind of figured it was a normal sound as the TXS dp certainly lets you hear everything ...
pezman04wrx is offline   Reply With Quote
Old 04-11-2005, 07:04 PM   #10
trex1200r
Member#: 56019
2004 Forester XT
there is a thread under the 2.0 engine forum that is conducting a poll on wether the waste gate flutter is improved, and if boost is improved with the actuater arm adjustment. Its running at about 10:1 that snugging up the arm reduced flutter without adverse affects. Some people report increased boost spike, so I would start with 1.5 turns and see if you notice any difference good or bad. I went conservative with 1.5 turns and it has worked well for me so far.
ap stage 2 w/boost controller?? yut_to_that AccessPort 6 11-07-2006 11:10 PM
Help! Installed DP, AP Stage 2 and no boost, stalls! idkew Factory 2.5L Turbo Powertrain 5 11-20-2005 04:48 PM
AP, Stage 2, Back Pressure, Boost Question? Snoop Factory 2.0L Turbo Powertrain 7 08-30-2005 12:53 AM
AP, Stage 2, Back Pressure, Boost Question? Snoop Engine Management & Tuning 0 08-29-2005 07:40 PM
Strange boost levels with AP Stage 2 Schleppy Engine Management & Tuning 8 05-11-2004 03:19 AM
Message Board Statistics All times are GMT -4. The time now is 02:24 PM.
