Welcome to the North American Subaru Impreza Owners Club Monday September 22, 2014
Old 04-01-2005, 10:49 AM   #1
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
Default perams psi value
is it important to set the psi value in perams? im supposed to be hitting 18 but its set to 20
thank you
WRXout is offline   Reply With Quote
Old 04-01-2005, 11:38 AM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
UTEC?
If you are set to map to 18 psi ad you hit 20 then you are going way past the 100% column of your maps.
2phless is offline   Reply With Quote
Old 04-01-2005, 02:17 PM   #3
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
you should try to set it correctly. Whatever you set your max psi to is going to effect the amount of fuel (load column) the car puts in. If your max psi is 16 and you are hitting 20, its putting in the same amount of fuel from 16-20 psi... its always going to be in the 100% column. If you set your max psi to 20, when it hits 16, it will be in the 80% load column and use the 80% fuel settings.
Rob
dosage0 is offline   Reply With Quote
Old 04-01-2005, 02:35 PM   #4
WRXout
Member#: 52908
ASPEN WHITE
so if i change this to like 18, will it effect fuel? retuneing needs to be done? is that what causes knock? and maybe hesitation i get every now and then, but it was tuned liek that wieerd
Old 04-01-2005, 03:36 PM   #5
dosage0
Member#: 42323
2004 WRX
Lots of questions at once.
Heres the big picture. You have columns that tell the car how much fuel to put in. They are done by taking the fuel parameters and dividing. So if you have set 20 psi as your absolute max, at 16psi your car would use the 80% column. 16/20 = 80%.
Just remember that the higher the % column the more fuel is being put in.
Now if your car is constantly hitting 100% load because your max psi is set low -- you arent using the fuel map very well. You should only hit 100% when your psi is maxed. Then the fueling will be maxed (not maxed out meaning dumping stoich... meaning putting in fuel at the highest rate needed). If you are only hitting 80% of what you can in terms of boost, you should only use 80% of that fuel amount.
Get it?
Why could this be a problem? Because if your car is setup to put in the same amount of fuel when you hit 16lbs as when you hit 20lbs, you are obviously going to be much leaner at 20 lbs.
If the car is running alright, then I wouldnt worry about it too much. Its just not tuned well. Its confusing at first, but your boost/timing/fuel maps are all related. Whatever boost you are at is divided by the max boost you set it your params. That gives you a load %. Thats used by the fuel map to determine how much fuel to put in.
Rob
Old 04-01-2005, 11:49 PM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
This is false.
If your max mapping parameter is set to 16psi, then the UTEC is applying the same correction factor for >= 16psi of boost.
x99percent is offline   Reply With Quote
Best Min and Max PSI Values for Progressive Boost Controlled Injection klattery Water/Methanol Injection, Nitrous & Intercooler Cooling 4 03-23-2006 01:00 PM
utec, perams question WRXout Engine Management & Tuning 2 03-21-2005 08:03 PM
Utec users... Make sure you have the right perams loaded! AZScoobie Engine Management & Tuning 9 10-25-2004 07:44 AM
How many PSI is too many PSI? virus67 Factory 2.0L Turbo Powertrain 9 07-03-2001 10:39 PM
Bosche BOV leaks over 7 psi, need recs for BOV for 0-12 psi ImprezaRS dot com Factory 2.0L Turbo Powertrain 22 05-10-2001 11:25 PM
