Old 03-15-2005, 02:32 PM   #1
gtlegg
Member#: 67837
04 tahoe
Default help me decide
ive been looking into the cobb exhaust for a while now and then i came across Stromung not to long ago...has anyone used any of these or heard them..i know cobb is like $660 and stromung ive seen for about $100 less....i cant decide. im looking for that 'boxer' rumble but dont want anything to noisy when cruising....has anyone got suggestions??!
gtlegg is offline   Reply With Quote
Old 03-15-2005, 02:34 PM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
my opinion: get the stromung, it isnt that loud when cruising but when you want to make some noise...o yah! and besides i think the dual-tip looks neat
svek is offline   Reply With Quote
Old 03-15-2005, 02:34 PM   #3
kastkc
Member#: 51141
2013 WRX
PBP
They're the same. COBB uses a Stromung catback and puts the COBB logo on the tip. Sounds very nice. One of the most refined sounding exhausts for the 2.5rs.
kastkc is offline   Reply With Quote
Old 03-15-2005, 02:38 PM   #4
svek
Member#: 82259
1999 impreza 2.2L
woah i didnt know that. well since the stromung is cheaper....
Old 03-15-2005, 02:41 PM   #5
gtlegg
Member#: 67837
04 tahoe
so cobb and stromung sound the same then kastkc? i mean if thats the case im def going for the dual tip stromung. and ill have to agree with svek there...if the cobb uses the stromung with just the 'COBB' logo, i mean WHY pay more, and then again. anyone know where to order one from?, only place ive seen them is teaguesauto.com
Old 03-15-2005, 02:42 PM   #6
gtlegg
Member#: 67837
04 tahoe
by the way is the dual tip stromung stainless steel??
Old 03-15-2005, 02:43 PM   #7
svek
Member#: 82259
1999 impreza 2.2L
www.spdusa.com
www.stromung.com
www.boxer4racing.com <----my fav site ever!
edit: yes full stainless
Old 03-15-2005, 02:49 PM   #8
gtlegg
Member#: 67837
04 tahoe
yea boxer4racing is good, thats where i found it but that site seems to be the same as teaguesauto.com too. thanks you guys help out much, you just saved me some $$$
Old 03-15-2005, 04:13 PM   #9
Siper2
Member#: 1134
2007 BMW 328xi wagon
I'm not sure if the Cobb unit is *exactly* the same. Best to read some other threads, first, because I've seen a lot of disagreements on that debate.
There's also Prodrive and the "Scoobysport" exhaust by www.haywardandscott.com if you like "rumble but no obnoxiousness," or Brullen.
Siper2 is offline   Reply With Quote
Old 03-15-2005, 08:36 PM   #10
kastkc
Member#: 51141
2013 WRX
PBP
the only difference i know of is the cobb is single tip and the stromung is dual.
You can try Stromung's site , just call them.
Old 03-28-2005, 05:53 PM   #11
gtlegg
Member#: 67837
04 tahoe
well, after a long wait ( about 5 days, im an anxious person) my exhaust finally got here. thanks to boxer4racing.com i am another owner of the stromung dual tip cat back. i cant wait to put this on an hear what this exhaust sounds like. everything turn out fine this week to, except for the weather, hours at work were cut so now ive got plenty of free time to install this as long as the weather permits. anyone know appox. how long it would take to install a catback, maybe i can do it between classes
Old 03-28-2005, 07:10 PM   #12
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
All depends on how stuck the bolts are. Maybe prep them with some WD-40 or the like first. Then, after that, it should be really quick quick. Unbolting the old pieces, removing from hangers and getting out from under car. Then reverse the process. If you prep the bolts ahead of time and you fully understand what you're going to do and in what order you'll do it--an hour maybe.
.02
Jared
gtwagon941 is offline   Reply With Quote
Old 03-28-2005, 09:14 PM   #13
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
do a straight pipe
Big_Hitter is offline   Reply With Quote
Old 03-28-2005, 10:17 PM   #14
kastkc
Member#: 51141
2013 WRX
PBP
I recommend PB Blaster on the bolts while there still warm, but not hot, let em soak for 10min then spray again if they look like they need it. put the car on some jack stands, give your self an hour to be safe. took me a half hour with a friend to do it. good luck, they will sound great.
Old 03-29-2005, 06:14 PM   #15
gtlegg
Member#: 67837
04 tahoe
sweet...so i got my exhaust on today and i must say that i love it. i love it all except for the fact that it is leaking where the mid pipe connects to the cat...its like the gasket dissenegrated(sp)...me and my friend tried something he had called rubber gasket or something and that worked well till i got home and it was leaking again....any ideas?
Old 03-29-2005, 06:22 PM   #16
Lavery
Member#: 77896
98 impreza 2.5rs
pick up some new gaskets from a dealer or try www.subaruparts.com I got mine from there. Did you get the midpipe too? I found that made it sound even better up in the cockpit. If not, you should get a custom on made, maybe with a high-flow cat too.
broooooooooottttttt
Lavery is offline   Reply With Quote
Old 03-29-2005, 06:45 PM   #17
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Go to your dealer and get a gasket. It is like $8 or something. That will fix it up perfect. Good to hear it is on. How long did it take you?
Jared
Old 03-29-2005, 07:13 PM   #18
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
Actually you should definately go for the Stromung, The Cobb has a Resonator as the Stromung is just a straight through pipe.
Caplin 2.5 is offline   Reply With Quote
Old 03-29-2005, 07:16 PM   #19
cabe
Member#: 55864
2002 WRX sedan
They're expensive IMO, but they do sound and look really good
cabe is offline   Reply With Quote
Old 03-29-2005, 07:47 PM   #20
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Resonator does NOTHING to hinder performance. Just tones it down a bit. Stromung actually makes one with a resonator too.
Jared
Old 03-30-2005, 01:19 AM   #21
uBuCk
Member#: 83227
2015 WRX Ltd
CWP
would the type XA Cat-back work on a '05 2.5rs??? and if anyone has this on thier car do you have any sound clips??
uBuCk is offline   Reply With Quote
Old 04-01-2005, 10:38 AM   #22
gtlegg
Member#: 67837
04 tahoe
i have the dual tip stomung rear muffler with the straigh mid pipe on. sounds amazing. not to loud to be annoying but sounds really nice when you get on it and nice and calm when cruising. it took me about an hour and a half to do the install my self.
Help me decide what alignment specs are for me! AlxSti Brakes, Steering & Suspension 5 09-19-2008 02:31 PM
Help me decide which career is for me. vadim Off-Topic 15 03-25-2004 08:23 AM
Photoshop my GC for me + help me decide the color pittkid333 Member's Car Gallery 23 03-24-2004 10:00 PM
WHICH exhaust for me??help me decide Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-12-2002 11:42 AM
