Old 04-01-2005, 03:51 PM   #1
mistaboosta
Member#: 68722
Default UTEC won't connect - all of a sudden
Last night I was out with one of my friend to tune his car. I connected the laptop as usual and tried to connect via Hyperterminal. The main menu screen pops up but can't enter any of the other menus. None of the keys are working.
I connected to his utec 2 weeks ago. Last night when I tried, I was using the same laptop, the same cables, the same utec and the same everything.
I tried to connect with 2 different laptops, and at least 3-4 different connector cables, none did help.
Other than that the red LED in utec is on and the car works normal. Tried to change the map to other mods llike Security or Valet, all works as normal.
What can cause such a problem? Any comments?
I've already tried to reflash utec but the reflash software didn't connect either.
mistaboosta is offline   Reply With Quote
Old 04-01-2005, 04:13 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
You using a serial cable or a USB adapter? You try another port in hyperterminal?
2phless is offline   Reply With Quote
Old 04-01-2005, 04:18 PM   #3
wrex03
Member#: 29963
04 sti
Did you try hitting the escape key?
wrex03 is offline   Reply With Quote
Old 04-01-2005, 06:02 PM   #4
mistaboosta
Member#: 68722
yess all of these are tried.
I have some pc knowledge so I tried to figure something out with the com settings but it didnt help.
Old 04-01-2005, 07:24 PM   #5
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Make sure the cable didn't get pinched...
T-WRX is offline   Reply With Quote
Old 04-02-2005, 04:05 AM   #6
mistaboosta
Member#: 68722
i've tried several different cables.
Old 04-02-2005, 08:02 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
caps lock on?
try hitting ctrl x a few times.
double check connection settings. 19k2, 8n1, no flow control.
make sure your com port is visible in device manager.
Old 04-02-2005, 02:40 PM   #8
Gethin
Member#: 2998
Sometimes I get the same with my v6b UTEC. It goes into a gremlin mode and nothing fixes it. I get the main screen, but selecting any menu option does nothing apart from refreshing the screen again.
So I shut it down, wait 5 minutes, rant and rave, then try again and it's fine. I have high quality cables and have tried all settings known to mankind, but every now and again the UTEC just sits there like a lemon.
Computers suck!
Gethin is offline   Reply With Quote
Old 04-02-2005, 03:28 PM   #9
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
For mine, I need to make sure Hyperterminal is running before I turn on the car. It's okay because the Windows95 boot up time on a Pentium 75 isn't too bad.
kennyvb is offline   Reply With Quote
Old 04-02-2005, 06:09 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....i recently had an issue connecting, too.....had to delete all my hypert connections and create and confiure a new one....and that worked....after i pissed about an hour away fookin'widit....
Old 04-03-2005, 06:26 AM   #11
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I had that issue too... went home, reset the ECU (too lazy to reach down and open the ECU protector plate).. viola! problem solved
feiron is offline   Reply With Quote
Whine noise all of a sudden in WRX - all gears at certain times Civ2Sub311 General Community 38 06-14-2015 04:33 AM
Just a friendly game of poker, when all of a sudden.... eurojax Off-Topic 21 06-26-2005 12:15 AM
What's with all the dog killing all of a sudden? now with a sword mr_disco Off-Topic 10 09-02-2004 10:00 PM
My valley = plethora of rednecks all of a sudden... Jimmy S. Off-Topic 7 11-06-2003 04:20 AM
