Old 04-01-2005, 07:53 PM   #1
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
Default what shoudl afrs be at crusing?
is 14.7 air fuel ratio appropriate? when crusing around 80 or 60 just cruising thanks.
WRXout is offline   Reply With Quote
Old 04-01-2005, 08:38 PM   #2
Nat
Member#: 759
2004 WRX
2000 SV650
Yes. The ECU will attempt to maintain stoichmetric A/F ratios.......about 14.7:1.
Nat is offline   Reply With Quote
Old 04-01-2005, 09:42 PM   #3
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Weird.... My 05 WRX always maintains 14.5 -14.6.... But I have never seen 14.7 anywhere except idle.
Running StreetTuner and Cobb STX Mods...(Stage 2)
buzz313th is offline   Reply With Quote
Old 04-02-2005, 07:59 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how are you determining that it runs 14.5 or 14.6?
Old 04-02-2005, 04:58 PM   #5
buzz313th
Member#: 37008
Delta Dash.... with the Stock Narrowband Sensor....
But I have read on the EFI forums, that it is sometimes better to run slightly richer than 14.7 at cruise.
Old 04-02-2005, 09:32 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
or wb with utec/tuna data log..
Old 04-03-2005, 06:23 AM   #7
feiron
Member#: 62327
2005 WRB STI
[S600BY]
notice at 0tps and 0% load the afr will go very lean... above 20s
you just dont want to run lean when boosting and at high rpm
feiron is offline   Reply With Quote
Old 04-03-2005, 12:37 PM   #8
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
It's because the injectors are completely cut for emissions and fuel economy.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
what shoudl i use to control boost WRXout Engine Management & Tuning 4 02-08-2005 04:42 PM
wrx with forester xt tranny, does anyone know what rpms will be at 70mph in 5th? wrxracer55 Transmission (AT/MT) & Driveline 0 02-14-2004 08:10 AM
What Time To Be At Install Fest 03UURX North West Impreza Club Forum -- NWIC 7 04-15-2003 11:03 AM
help with what boost should be at. Bauhaus Mid West Subaru Owners Club Forum -- MWSOC 2 05-20-2002 09:46 PM
('93-'01) what vendors will be at Carlisle? auricom Impreza Forum 1 05-03-2001 09:50 PM
