Old 07-23-2001, 07:32 PM   #1
HonduhEater
Member#: 6882
2005 STI
Java Black Pearl
Default Smoke/Steam coming out of vents??
Hey there
I was driving on the freeway today when i turned my A/C off cause it was getting too cold. Sure enough 5 mins later i was sweating and needed to turn it on. Then all of a sudden smoke/steam started pouring out of the vents (w.t.hell is going on i thought???) I proceded to turn off the vents and pull over. When i went to turn them on again the smoke/steam was gone.
I can recreate the even by driving for a while w/out the A/C on (after having had it on for a while first) and then turning it back on again. FYI, the temp was about 90 outside and today is the only time its happened so i dont know if it will happen again tomorrow, whether its just the temp or what. The smoke/steam stops after about 10-15 secs and the car is fine afterwards. There is no smell but it looks really scary
Anybody else experienced this...it scared the **** out of me
HonduhEater is offline   Reply With Quote
Old 07-23-2001, 08:00 PM   #2
aspera
Member#: 7879
It appears what you have is a loose nut behind the steering wheel. A Trunkmonkey should remedy your problem. You should be able to pick one up for under a grand.
aspera is offline   Reply With Quote
Old 07-23-2001, 08:19 PM   #3
pottsie350
Member#: 6110
98 Impreza L
Red
Does the trunkmonkey usually come with it's own set of tools? I've been considering getting one.
The mist is normal. Think fog in a low lying valley before the sun burns it into vapor.
pottsie350 is offline   Reply With Quote
Old 07-23-2001, 09:51 PM   #4
fastwrx
Member#: 7398
2004 2004 WRX-STi
Hi Honduh,
You can sleep at night, now. This is NOT smoke. It is condensed moisture from the outside air. This becomes most noticable when there is a lot of humidity in the air. You may notice it even more when it's raining. The moisture from the outside air is drawn in, and your A/C rapidly cools it forming condensation.
Try this... duplicate your "smoke" situation, and then switch your A/C to "recirculate" mode. After a few seconds, you will notice the condensation ("steam") disappear.
So no worries, mate! (feeling Australian there for a second!)
Mike
fastwrx is offline   Reply With Quote
Old 07-24-2001, 10:31 AM   #5
boostaholic
Member#: 7224
2002 WR Blue WRX
13's with just a MBC
I had this happen to me on the 94/894 the other day... at first i was like ***?! but then I realized it was only condensation that was forming in the vents. What did disturb me though is that mold is much more apt to form there now
boostaholic is offline   Reply With Quote
Old 07-24-2001, 12:56 PM   #6
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
you can take care of the mold by turning off the AC and turn on the heat for a minute or so before shutting off the car.
ChrisW is offline   Reply With Quote
Old 07-24-2001, 06:03 PM   #7
HonduhEater
Member#: 6882
2005 STI
Java Black Pearl
yeah it seems like its not just me experiencing it. I figured out it was just steam after a while cause smoke always smells and whatever was coming out of the vents didn't. It still scared the shiht out of me though
So whats burning when smoke is coming out of exhaust... WolfInSheepsCLothing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 07-04-2008 11:34 PM
Funk smell coming out of vents!? teiva-boy Interior & Exterior Modification 21 11-24-2007 11:05 PM
hmmm...smoke/steam coming out of radiator...help? 98subyrezaRS Normally Aspirated Powertrain 11 02-28-2006 03:05 PM
smoke/mist coming out the ac vents? ants wrx Tri-State Area Forum 15 06-28-2005 11:01 PM
Uhh... smoke coming out of my hood vent.. Clutch? Siper2 New England Impreza Club Forum -- NESIC 14 06-10-2002 10:39 AM
