Old 04-01-2005, 09:32 PM   #1
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Default 05 WRX MAF Calibration & Fuel Trim (Ecutek/StreetTuner)
Can anyone please confirm these conclusions.
1. When fuel learning and Fuel Correction is positive, the ECU is adding Fuel to the mixture. And when negative it is subtracting fuel from the mixture.
2. Resetting the ecu with the AP clears the Fuel Learning Tables.
3. The switchover point from CL to OL is indicated by both Fuel Learning and Fuel Correction going to zero. Thus, when in OL the ecu is not making any fuel adjustments based upon what it has learned in Closed Loop.
4. My Car is running Fuel Learning values of anywhere from 0 to 8, so an average would be 4, does that mean that I need to calibrate the Maf so that Fuel Learning is as close to 0 as possible. And if I did that, then I could count on Fuel Ratios to be actual when in open loop.
5. So if my fuel learning is positive (adding fuel), then it is correct to assume that since my ecu is adding fuel to get to the targets, that the maf is sensing less air than is actually flowing into the engine......then to correctly calibrate the MAF, I need to increase the values of air to voltage to let the ecu know that there is actually a larger volume of air flowing at a given voltage than before. Which then would allow the ecu to inject a bit more fuel for a correct mixture. And then once the ECU no longer needs to make as much fuel Learning adjustments, then I can count on OL fueling to be "more correct".
That was a handful....
So anyway... if anyone could correct me on any of these points, I would like some guidance...
buzz313th is offline   Reply With Quote
Old 04-02-2005, 09:42 AM   #2
cnstman
Member#: 9548
2004 WRX STi
PSM, 10.741 @ 126.29
also interested.
cnstman is offline   Reply With Quote
Old 04-02-2005, 10:51 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Correct. Positive adding fuel, negative removing fuel.
If it is doing a full reset like you can with the EcuTek deltadash then yes.
After a quick chat with my EcuTek expert... Edited my post..
On the WRX when the ECU goes into open loop fueling short term correction goes to zero but long term is locked at a learnt fuel value.
See image from delta dash
This was from my WRX 03 wagon at the track. You can see that each time the ECU goes into open loop the ST goes to 0 but the LT learning stays negative in my case.
This action was one of the drivers behind TurboXS bringing out Open Loop Fueling. This fueling offset will change your WOT tune over time. The UTEC OLF controls all the fueling so the LT trim does not effect the WOT tune.
You will never get ST to stick at 0 but if you can get LT between +-7 you are doing pretty good.
100% correct. Let us all know how you get on doing this.
mick_the_ginge is offline   Reply With Quote
Old 04-02-2005, 04:55 PM   #4
buzz313th
Member#: 37008
Thanks for your reply...
And will do..
WTT: (DeKalb/Chicago IL) 05 STi door cards & carpet for 05+ WRX door cards & carpet WhiteHawkSTi MWSOC Private Classifieds 9 03-07-2010 06:34 PM
FS: 05 WRX ECU Stage 1 flash by ECUTEK. Cheap! PoOrMaN's{WRX}BrS SCIC Private Classifieds 0 10-31-2009 02:19 PM
02-05 wrx MAF sensor eddie1982 Private 'Wanted' Classifieds 5 05-14-2006 11:22 AM
02-05 WRX MAF sensor eddie1982 Private 'For Sale' Classifieds 1 05-11-2006 01:25 PM
Will a 05 wrx MAF sensor work on a 02 wrx eddie1982 Factory 2.0L Turbo Powertrain 4 05-11-2006 03:42 AM
Message Board Statistics All times are GMT -4. The time now is 08:39 PM.
