Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-01-2005, 09:36 PM   #1
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Default Rescaling X&Y Axis (Ecutek/StreetTuner)
When rescaling the x and y axis on the ST maps, is it ok to have, different scales for relating axis on the maps?
Is it ok to have the knock correction load axis slightly different than the Base ignition map load axis?
Do any of the map axis need to match up?
Does the ECU look up each map seperately and then add or subtract values against each other, or does the ecu need to look up common cell sites to work effectively?
buzz313th is offline   Reply With Quote
MAF rescaling Freon Commercial ECU Reflashes 0 05-26-2006 05:32 PM
Can the car withstand 400WHP with a good tuning (with ProTuner or StreetTuner)? Ozer Engine Management & Tuning 13 11-11-2005 10:45 AM
New Coldplay Album X&Y out today PhatMatt Off-Topic 49 08-26-2005 03:53 PM
05 WRX MAF Calibration & Fuel Trim (Ecutek/StreetTuner) buzz313th Engine Management & Tuning 3 04-02-2005 04:55 PM
Maf Limitations (Ecutek/StreetTuner) buzz313th Engine Management & Tuning 2 04-02-2005 08:13 AM
