Old 04-01-2005, 10:32 PM   #1
112nick
Member#: 83735
'06 Impreza WRX STi
Question Help!! I can't get full throttle after CAI install.
I need help figuring out what the problem is with my 99 Rs. After installing an INJEN CAI I was unable to get full throttle. I'm getting the hesitation from hell. I know that it must have something to do with the MAF sensor, but can't pin point the problem. What do I do now? Help!!
112nick is offline   Reply With Quote
Old 04-01-2005, 10:35 PM   #2
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
did you reset the ecu after installing it?
00Maddog is offline   Reply With Quote
Old 04-01-2005, 11:08 PM   #3
112nick
Member#: 83735
'06 Impreza WRX STi
No I did not..... What do I need to do?
Old 04-01-2005, 11:46 PM   #4
cabe
Member#: 55864
2002 WRX sedan
unplug the battery and pump the brakes. let sit for a few minutes. hook battery back up. done.
you'll know you did it right if your preset radio stations are gone. good luck!
cabe is offline   Reply With Quote
Old 04-01-2005, 11:47 PM   #5
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
my understanding is u disconnect the negative battery terminal, hold down the brake pedal, and bump ur system until the brake lights go out. then reconnect the terminal and drive around like u normally do.
bongchild is offline   Reply With Quote
Old 04-01-2005, 11:50 PM   #6
cabe
Member#: 55864
2002 WRX sedan
your understanding is correct, my good sir.
Old 04-01-2005, 11:58 PM   #7
112nick
Member#: 83735
'06 Impreza WRX STi
Thanks guys........I'll definately keep that proceedure in mind. I've got a friend of the family that is going to do all of that for me in the morning. But I did find out something interesting that is actually the biggest cause for my Hiccup from hell.......... It's coming from the air filter. The oil used on the air filters coats the MAF sensor during a drive, in turn doesn't allow the sensor to report to the ECU properly, forcing a starve for fuel. Not allowing full fuel pressure.
Old 04-02-2005, 05:55 AM   #8
Hayes
Member#: 11808
You must be using one of those high maintanence high sand flow aftermarket filters??
Hayes is offline   Reply With Quote
Old 04-02-2005, 01:15 PM   #9
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
that or he oiled the damn thing too much...
allsubaru83 is offline   Reply With Quote
Passenger headlight turns off after CAI install khizzle Newbies & FAQs 3 07-13-2008 05:15 PM
Another protune after CAI install? red330I AccessPort 6 11-10-2006 08:02 PM
car no start after CAI install? help please Solomon Normally Aspirated Powertrain 12 07-30-2003 12:31 AM
can't get full boost... uppipe? angryfist Mid West Subaru Owners Club Forum -- MWSOC 5 05-03-2003 10:01 PM
Check engine light after CAI install MporTluvR General Community 10 01-16-2002 10:18 PM
