Old 04-02-2005, 01:53 AM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default 2.2t ring gap
I am having a difficult time digging up info on piston ring gap for the EJ22T. Someone on the board had a link to many useful subaru manuals (http://www.main.experiencetherave.co..._manual_scans/) but I can't seem to dig up any real numbers for this application.
Anyone have any tips for a starting point for the piston ring gap for a 2.2? I understand that higher HP might call for a little more gap than stock, but I would like to know what stock specs are.....
Matt
TyranosaurusWRX is offline   Reply With Quote
Old 04-02-2005, 02:43 AM   #2
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I would also like to offer my current findings:
2.0 ltr (WRX)
Top Ring: .20 - .35mm (.0079 - .0138")
2nd ring: .35 - .5mm (.0138 - .0197")
Oil ring rail: 0.2 - 0.7mm (.0079 - .0276")
2.5 ltr (STi)
Top Ring: .20 - .25mm (.0079 - .0098")
2nd ring: .37 - .52mm (.015 - .020")
Oil ring rail: 0.2 - 0.5mm (.0079 - .0197")
Maybe I should average them...
Old 04-02-2005, 03:05 AM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
OK, to answer my own thread......
Ring gap for the 2.2:
The first two rings are exactly the same as the 2.5 (Sti)
The oil rail are exactly same specs as WRX 2.0
Old 04-03-2005, 01:36 AM   #4
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
Default TyranosaurusWRX
Is there any way that you can do a right up of how to properly put the rings on the pistons please. Also do you know what the gap would have to be if i went .020 larger of a piston for 2.2 and of course i bored my 2.2 to 3.825.
Do you know if there is a different way to put rings on for different pistons?
I'm getting CP's??
Thank you
mario
marios03wrx is offline   Reply With Quote
Old 04-03-2005, 01:57 AM   #5
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Honestly, I wouldn't feel right about doing a write up on something that I am just learning to do myself. If I can help you out, I will though.
When you say 3.825, are you referring to the bore diameter? At any rate, the only thing I know is the above info, which is for stock specs. It's my understanding that you want to be on the higher side of things (ie a little wider ring gap) for higher horsepower applications to allow for more room for ring expansion under high heat. The ring gaps can change depending on bore. So I really don't know for sure how to come up with a good number for that.
Old 04-03-2005, 03:47 AM   #6
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
You might want to check this thread - http://forums.nasioc.com/forums/show...4&page=3&pp=25
It mentions .004 for every inch of bore, I would say minimum.
Old 04-03-2005, 03:54 AM   #7
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
Thank you for the info
Old 04-19-2005, 03:18 AM   #8
02Toyowrx
Member#: 56520
It looks like Subaru uses the multiplyer 2.2 for the top ring, and 4 for the second ring, and around 2.2 for the oil rings. Subaru has the tightest tolerances, unbelievable but that is good for power.
So Example
1st ring
WRX bore= 3.62" x 2.2= 7.964 which translates to .0079 tighter tolerance the better.
2nd ring
WRX bore=3.62" x 4= 14.48 which translate to .01448
Note: This only would apply when using the stock pistons & rings.
02Toyowrx is offline   Reply With Quote
Old 04-19-2005, 03:18 PM   #9
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
Right on 02toyowrx
Thanks
OR:FS - Misc Engine - V7 Cams / WRX Cams / WRX Rods / 2.2t Crank / 2.2t Rods mick_the_ginge Engine/Power/Exhaust 6 03-20-2007 03:17 PM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 1 07-26-2006 10:33 AM
WTT: my auto 2.2T for your manual 2.2T shemoves South West Impreza Club Forum -- SWIC 1 02-27-2006 04:10 AM
Ring Gap Question Andursun0013 Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-25-2005 03:02 AM
anyone got a engine layin around? 2.5? 2.2? 2.2t? mcu81 Tri-State Area Forum 6 07-20-2002 12:36 AM
