Old 04-02-2005, 01:22 AM   #1
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Question Is this normal??
When I'm cruising on the freeway I noticed that when I hit 70 the needle on tach would switch between 3k and the notch right before 3k. I can also feel the car shaking ever so slightly on and off...
It used to have a consistent pattern, but now it seems more erratic. I also notice it happening when I'm accelerating past 70. The needle drops a notch and the car doesn't accelerate, then it jumps a notch and the car picks up. It doesn't happen when I rev the engine in park. I don't have overdrive or cruise control, the A/C is disconnected completely (both wiring harnesses unplugged), and i have been religious about maintenance.
It's not the auto tranny switching between 3rd and 4th because the jump in rpm's is 1500 when i go from D to 3. After installing a CAI and catback, I can hear the tone of the engine get lower when the needle drops and higher when the needle jumps; like it's slowing down, then speeding up again.
Is this normal??
bongchild is offline   Reply With Quote
Old 04-02-2005, 01:28 AM   #2
Handsdown
Member#: 29355
automatic? it has overdrive, doesn't it? my bet is overdrive.
did you ask the drivetrain forum?
Handsdown is offline   Reply With Quote
Old 04-02-2005, 04:07 AM   #3
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Does this happen with your a/c on? COuld be possible. Hmm
ejicon is offline   Reply With Quote
Old 04-02-2005, 01:13 PM   #4
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
if that happens while you have the cruse control on it means that you car is just slowing to the desired speed that you have choosen...
allsubaru83 is offline   Reply With Quote
Old 04-05-2005, 12:03 AM   #5
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
As far as overdrive, I don't think my car has it. A/C is currently disconnected because the compressor was seized up. I don't have cruise control. I also noticed that it happens when I am accelerating from like 70 to 80. The needle will climb, then fall a notch, then go back up a notch, and so on and so forth.
Old 04-05-2005, 12:11 AM   #6
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
This is a very serious problem. I diagnose it as being caused by: "Automatic Transmission". The only solution is to swap it out into a manual.
Its expensive, but it will be worth it
powerlabs is offline   Reply With Quote
Old 04-05-2005, 01:00 AM   #7
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Heh, I agree with u on that. manual would be much more fun to drive. but the whole money thing....
Old 04-05-2005, 01:03 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
my guess would have been your AC ... or defrost cycling on and off.
sure it's completely disconnected??
Old 04-05-2005, 01:12 AM   #9
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
yep. i have the wiring harness to the compressor as well as the smaller harness coming off of that one disconnected. funny story behind that....
i don't see any other wires going to it, so im pretty sure it's completely disconnected.
Old 04-14-2005, 01:58 AM   #10
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
bump
anyone wanna help put my mind at ease??
Old 04-14-2005, 02:04 AM   #11
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i notice on mine that i will go around a corner then i will get on the gas a little and the tach will jump about 500 rpm. it doesnt shift. the tach just kind of jumps a little and then the car accelerates out. its really weird. and btw its an auto too
svek is offline   Reply With Quote
Old 04-14-2005, 02:29 AM   #12
Handsdown
Member#: 29355
i'm still going to say it's a transmission thing. automatics do wear out, you know...
Old 04-14-2005, 12:56 PM   #13
BoneStockTS
Member#: 80670
The 4EAT has a "power mode" and an economy mode, the revs drop slightly when it goes into econo mode. It could be that it simply goes into power mode when you do this.
And those of you that knock auto trannies, if you don't like 'em, don't buy 'em.
BoneStockTS is offline   Reply With Quote
Old 04-14-2005, 07:52 PM   #14
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
What about cruising at a constant speed? Is it supposed to go in and out of it at random intervals?
Old 04-14-2005, 09:58 PM   #15
svek
Member#: 82259
1999 impreza 2.2L
hmm i didnt know that.
Old 04-14-2005, 10:11 PM   #16
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
My 95 Impreza has a light that comes on the dash when it's in Power Mode, it means it will now Shift at the red Line instead of shifting at 4000 when the red line is 6000.
The newer Subaru's did away with the light but the power mode is still there.
SubaruImpreza_power is offline   Reply With Quote
Old 04-14-2005, 10:44 PM   #17
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I'm guessing it has something to do with the torque converter. It may be completely normal since it only happens at that particular speed in that gear. When the car wants to go into overdrive the tranny will "lock up" the torque converter so that it does'nt have to rely on the "fluid coupling".
question:
1.Does it do this once during the transition and then it's fine?
2.If you were to accellerate after this transition does it kick down and then do it again once you're done accellerating?
Sounds like it might be normal to me. I could be wrong though.
Good luck
Tim Sanderson is offline   Reply With Quote
Old 04-15-2005, 10:57 PM   #18
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Originally Posted by Tim Sanderson
question:
Good luck
1. It kicks in at 70 mph and keeps on doing it as long as im at 70 or above.
2. It seems to happen regardless of whether I'm accelerating or cruising. However, when I'm giving it gas and the needle on the tach is 'down' the car won't accelerate but then the needle will jump a notch (about 250rpm) and the car will pick right up.
My clutch is dead at 42K is this normal? Ripper Normally Aspirated Powertrain 9 06-07-2012 07:46 PM
is this normal for the normal headlight sequence for an 07 outback? jawwadh Electrical & Lighting 6 08-08-2008 11:34 PM
Is this normal to do this? SubaruImpreza_power Newbies & FAQs 13 06-23-2004 08:37 AM
Is $2,500 for taxes, plates and doc fee sound crazy or is this normal? twiztid General Community 10 11-07-2002 09:36 PM
Reserve is hard to engage 3 out of 5 times... Is this normal? MrP0nch0 Technical Forum Archive 23 08-29-2000 05:28 PM
