Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 07-23-2001, 08:18 PM   #1
chinaman
Member#: 6731
2000 2.5rs
perl blue
Question is it legal?
is it legal to have Nos in our car at E-twon (edmonton)
i hread rumor that if cop sees it they will take ur whole car away.
anyone knows???
chinaman is offline   Reply With Quote
Old 07-23-2001, 09:33 PM   #2
Keenan
Member#: 2277
2001 Impreza 2.5RS
Sedona Red Pearl
I believe there was a post on this before in the Canada Forum. The general thoughts were that it was illegal. However, there was no clear quotation of the law to prove one way or the other.
Keenan
Keenan is offline   Reply With Quote
Old 07-23-2001, 11:40 PM   #3
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
I'd have to ask my friend (pro drag racer) but I think he said this to me before...
I think he said it's legal... and you don't need a permit... because NOS isn't explosive (or a dangerous good).....
Robin
www.ottawasubaru.com
Robin2 is offline   Reply With Quote
Old 07-24-2001, 11:27 AM   #4
inpreza kid
Member#: 3334
i've heard from a number of people that its illegal. do no doupt about that. thing i would be worried is what the cops are going to do if you get cought on the bottle. i heard that cops own your car if you get cought but i guess it also depends on the cop. can anyone correct me on this?
inpreza kid is offline   Reply With Quote
Old 07-24-2001, 02:20 PM   #5
nikkicalves
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
2000 Impreza
Tanned - BRP
I know in Toronto, If you have the system installed you are ok - BUT if you have the bottle inside the car or hooked up you are screwed. BTW Nitrus Oxide is dangeously explosive when pressurized and can blow up just like any other gas. Yes they can reposses your car and they can take out the illegal conponents of the system. Same thing with an exhaust. If they tow the car to the impound, the mechanic will deem what is for off road use and take it off and charge you for the labour and tow and impound fees. Believe me it happened to my friend and there isn't a thing you can do about it. You have to choose your mods wisely.
Nick.
BTW, why nos? It is only good for drag racing and you can only push a 70 shot safely. Go TUUURRBO if you want to go fast all the time.
nikkicalves is offline   Reply With Quote
Old 07-24-2001, 03:28 PM   #6
spt_impreza
Member#: 3004
guys,
NOS is ILLEGAL!!!!!! i am 150% sure it is illegal!! this info is comming right from the horeses mouth!!! and btw- you shouldnt lose your car...and whoever said it all depends on the cop, well your right!! some will ticket you some will not. BUT be well award that if you get caught using it there is oh hmmmm about a 100% change of getting a "coupon". anymore Q's just ask
spt
spt_impreza is offline   Reply With Quote
Old 07-24-2001, 07:10 PM   #7
chinaman
Member#: 6731
2000 2.5rs
perl blue
turbo is too $ man.
same as swaping the engine.
i also think of improving the handleing but i guess i can deal with it later.. caz compare to all other car we alreayd got the AWD. so i want to spend some bucks on Speed.
with the limited money i have, nos is the fastest way i can speed up the car.
well, if there is anyother way i can make my car faster.
spill it!
any advice is good man.
thx
Old 07-24-2001, 09:28 PM   #8
markus
Member#: 438
2004 STi
White on Gold
Exclamation
As Steve (spt) has already posted, NOS is definately illegal...in Alberta!!
As for other Provinces......I don't have a clue!!
BTW, you're garuanteed to make short work of your motor if you do not have the proper fueling system in place with NOS. Stay away from the "Dry" systems and the "Wet" systems should have an alternate fuel supply seperate from the stock injectors.
markus is offline   Reply With Quote
Old 07-25-2001, 03:06 AM   #9
lophilip
Member#: 8576
2000 TS Impreza Seda
NOS is definately illegal in Alberta, but getting caught with NOS is another thing entirely. I'm not sure if its illegal to install on a street car or is it just illegal to use (turn on) while you're on city roads.
I would definately recommend against a NOS system. It gives the biggest bang for the buck, but it causes excessive engine and transmission wear. If you're thinking of NOS cause its cheaper than a turbo, think again. It's more expensive in the long run because of the damage to your car.
It should be noted that Turbo also causes more stress on an engine too, although not nearly as much as one shot of NO2. Supercharges, although generally not as powerful, are slightly cheaper than turbo and has less maintance (if you choose a good brand).
lophilip is offline   Reply With Quote
Old 07-25-2001, 01:28 PM   #10
chinaman
Member#: 6731
2000 2.5rs
perl blue
well...k
let's put nos away for a sec then..
if i wnat to install cam and pulley.
what brand do u guys suggestion?
cost of cam and pulley. plus installion will it be under 1000 bucks CND ?
How much HP can i gain from those ?
Old 07-25-2001, 01:33 PM   #11
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
chinaman - just labour alone @ a good Subaru dealer is over $500CAD (w/ tax) to install cams. Rates at Subaru of Calgary are $75CAD/hr. For $1000CAD, you won't be able to buy and install cams. (unless you install it yourself)
GTBGUY is offline   Reply With Quote
Is it legal to have a touchpad screen (navigation) where the clock is? casualsurfer Electrical & Lighting 13 08-25-2004 08:15 PM
Changing Uppipe in MA: is it legal? Bradus New England Impreza Club Forum -- NESIC 4 12-01-2001 02:21 PM
Is it legal? jacktam1 Vancouver Impreza Club Forum -- VIC 9 07-20-2001 09:47 PM
Is it legal? au112 Vancouver Impreza Club Forum -- VIC 9 02-26-2001 07:08 AM
No turn signals.....is it legal??? KC New England Impreza Club Forum -- NESIC 7 11-16-2000 08:21 AM
