Old 04-02-2005, 01:25 PM   #1
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Default TWE cams for the 2.2L ?
I had the post "making 2.2l horsepower" and someone had mentioned that TWE made a set of cams for the 2.2L. I went over to there website but alls i could find were cams for the 2.5L anybody know if they actually do make cams for the 2.2L and could cive me a link to the website thanks
99subi is offline   Reply With Quote
Old 04-03-2005, 12:52 AM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i looked on the site too and couldnt find them. although they said delta cams can regrind them for you. and somewhat cheap.
svek is offline   Reply With Quote
Old 04-03-2005, 01:21 AM   #3
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
sounds like some kind of idea. i guess im going to have to look into that. i was thinking of possibly putting on 2.5 heads which would lower my compression ratio and turbo my 2.2 but i still dont no. this motor has no aftermarket parts. seems like if your a 2.2 non turbo subaru your kind of screwed
Old 04-03-2005, 09:13 AM   #4
G.Subramaniam
Member#: 64528
Delta cams makes cams for the 2.2L
G.Subramaniam is offline   Reply With Quote
Old 04-03-2005, 10:10 AM   #5
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
So how did the Delta cams make your car run? Anything to watch out for like Cels or install problems?
Say are you getting a spiff from Delta
GuyLR is offline   Reply With Quote
Old 04-03-2005, 10:47 AM   #6
Slack
Member#: 17548
Jeez louise, dude! You just posted a thread a few days ago and you were told that Delta makes cams for the 2.2l for $130!!!! TWE probably could make you some custom cams, but they would cost a lot more. There isn't much of a market for 2.2's, but at least Delta has us covered.
Mick
Slack is offline   Reply With Quote
Old 04-03-2005, 01:51 PM   #7
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
sry man
Old 04-03-2005, 02:55 PM   #8
Slack
Member#: 17548
Sorry, I am running on too little sleep and was a bit cranky (no pun intended) this morning. I apologize for my frustrated reply.
Mick
Old 04-03-2005, 03:19 PM   #9
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
nah man its all good
Old 04-04-2005, 11:08 AM   #10
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
99subi - your EJ22 should be a phase 2 head (ie: it should be using a roller rocker design, shared w/ the EJ25 SOHC head). You should be able to run the EJ25 SOHC cam offered by TWE.
GTBGUY is offline   Reply With Quote
Old 04-04-2005, 05:04 PM   #11
svek
Member#: 82259
1999 impreza 2.2L
yah my 99l is phase II but i didnt know you could use the ej25 cams...what years were the sohc?? i might look into this
Old 04-04-2005, 08:38 PM   #12
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
I emailed Cobb about using the 2.5L cams in my OBS Phase II EJ22 about a year ago and they said that they wouldn't work but the guy didn't really convince me. I think either nobody has ever asked or they weren't sure and it was just easier to say no than have me buy their cams and have a problem.
The valve gear and layout appears to be identical. The EJ25 cams have a touch more lift and a degree or two more duration and overlap I think. Somebody out there must know for sure. If they do fit I'll bet that even the stock 2.5 cams would be worth a few HP.
Old 04-04-2005, 10:32 PM   #13
Slack
Member#: 17548
I would call TWE directly if you want some accurate info.
Mick
Old 04-04-2005, 11:30 PM   #14
iON Performance Inc
Vendor
Member#: 7673
The Phase 2 2.2L SOHC share the same valvetrain design as the Phase 2 2.5L SOHC. Hence you'll be able to use cams designed for the EJ25 SOHC in your EJ22.
iON Performance Inc is offline   Reply With Quote
Old 04-04-2005, 11:31 PM   #15
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
i think im going to call TWE and find this out becuase cams would be a nice thing to have for us 2.2 guys ,thanks to GTBguy
Old 04-06-2005, 10:47 AM   #16
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Post up what you find out from TWE... I'm sure it would be good info for others as well.
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 04-08-2005, 12:44 PM   #17
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
Bump. Anything to report?
Old 04-08-2005, 12:51 PM   #18
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
ive called them twice the first time i was told that they wouldnt work and the second time i was told they would i dont know what the hell they are doing over there but they have no clue what they are talking about . i am going to call aain and see what i get this time
Old 04-08-2005, 01:00 PM   #19
GTBGUY
Member#: 2003
'99 BGP Legacy GT
99subi - who'd you talk to there? It's probably best to email them on their tech email address.
A good source of cams for NA 2.2L G.Subramaniam Normally Aspirated Powertrain 35 11-11-2004 12:07 PM
Does anyone make cams for the 2.2L cybin Normally Aspirated Powertrain 31 12-03-2003 03:46 AM
anyone know the CR for the 2.2L Turbo heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-21-2001 09:24 PM
Does MRT make a single exhaust port header for the 2.2L? 96Lconversion Normally Aspirated Powertrain 4 03-14-2001 12:38 AM
Does anyone have the torque/hp curves for the 2.2L?? 96Lconversion General Forum Archive 0 02-28-2001 07:13 PM
