Old 04-02-2005, 02:44 PM   #1
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Default Interior Color Change Tutorial: OEM Boost Gauge
OEM Boost Gauge Color Change Tutorial
What you need:
1 (.2) Lamp Cover CLICK ME
2 Flat Screwdrivers
Procedure:
Drop down steering height adjuster arm and put steering in lowest setting:
Insert the two screwdrivers in between the rubber housing and the gauge itself and gently pry it out towards you. Take your time, you will almost need to gently wiggle it out. Vary the positions between 12 and 6; 3 and 9 o'clock when prying:
Take a look at the black plastic tube on the back of the boost gauge, once located, gently push in into the back of the gauge. This is done to create the slack necessary to pull the gauge out. Wiggling it out gets easier the more the gauge comes out, don't get discouraged, take your time and dont scratch or break anything. Once you can catch the lip of the gauge (as seen in pic below) try wiggling it out just holding the lip. Remember to keep giving it more slack by pushing in the black "wire loom":
When you manage to wiggle it out it will look something like the pic below. The top connector is for the bulb power, the bottom is the vaccum line - its a mechanical gauge. But the middle black knob is what concerns us, it is the bulb (righty tighty, lefty loosey applies), unscrew it and put a cover over it.:
Reverse order of install to put your car back together, be sure to gently pull the slack back out.
Important Note: Some of the new-gen boost gauges have an LED built into the gauge, becuase LED's dont burn out, they dont make them removable and there is no access to it. If you dont see a black knob there is no way to change the color of your gauge. Please take a look and if you don't have one post your car info.
*MY's this applies to will be edited in here when you inform me*
Note: This is the one color change where I reccommend using only one bulb cover. This is because its not built like most gauges, its simply a halo of light that illuminates the face from the front, using two covers I found it to be too dark. On a side note, I tried blue lamp covers and it came out a little too teal for my taste, the red color seems to work far better.
Modification of your car involves risks and may void your warranty. I can not be held responsible for the modifications you consciously decide to undertake nor the results of doing so. If you believe anything is incorrect in this post or you have something to add please PM me.
Trunk_Monkey is offline   Reply With Quote
Old 04-02-2005, 05:05 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'll add that you can replace the 2.1W bulb with a #2723 bulb which is 2.3W, to make it noticeably brighter. When I first got my car with the OEM gauge pack I found the boost gauge to be difficult to read at night, but by changing the bulbs in the gauges to the 2.3W, and removing the condom from the one in the boost gauge (didn't care about the color) it got much brighter and easier to read.
For purposes of this thread the brighter bulb should help.
Also I see your gauge doesn't read 0, unfortunately this is very common.
Old 04-02-2005, 06:06 PM   #3
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Nice tip with the brighter bulb. I thought the below 0 reading was fine, as I am above sea level?
Old 04-02-2005, 07:23 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The gauge should compensate, the mechanical movement measures the differential between the ambient pressure and the manifold so your elevation makes no difference. Look at the OEM gauges on other cars in your area, you'll probably see some that read zero and some that don't.
Old 04-02-2005, 08:18 PM   #5
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
excellnet. thanks
scoobdude is offline   Reply With Quote
Old 04-02-2005, 09:03 PM   #6
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
That would mean I am boosting above stock pressure, with a stock turbo and EM. Or the error is not directly proportioning,
Old 04-09-2005, 07:01 PM   #7
IntraWRX
Member#: 20773
Midnight Black Pearl
you can also use the #74 size LEDs in place of the bulb. i used a blue LED and it's significantly brighter than than what it used to be. i also used the #74 LEDs inside the gauge cluster, but the light dispersion in the gauge cluster isn't as good as in the boost gauge (ie boost gauge is brighter than gauge clusters)
i got my LEDs from here: http://autolumination.com/74.htm
you can also find them here http://www.superbrightleds.com/specs/74_t15.htm
obviously, these are not the only places you can find them and you can probably find better prices elsewhere.
IntraWRX is offline   Reply With Quote
Old 04-09-2005, 10:01 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Instead of a 'condom', you can use a permanent marker to color the bulbs, too...Sharpies work great
Old 04-09-2005, 11:55 PM   #9
IntraWRX
Member#: 20773
Scotty, was wondering if blue sharpie would end up looking teal like the condoms do? or do they look bluer than condoms?
Thanks!
Old 04-10-2005, 01:18 PM   #10
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
My guess is still teal, but give it a shot, you can probably scape it off.
Old 04-10-2005, 02:36 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....the green Sharpie looks teal...matches the '02-03 dash lights fairly well......and it comes right off with a bit of alcohol...dunno about the blue....try it and see
...you can experiment with how much you cover the bulb....ie....just the tip....or one side....or stripes....to get the ammount of color you want.....
Old 04-10-2005, 02:38 PM   #12
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Nice idea with the striping you could probably even mix colors to get the one you want.
Old 04-11-2005, 01:13 AM   #13
IntraWRX
Member#: 20773
striping?! sweet, hot pin---ermm, STi pi--- cherry blossom red, here i come!
Old 04-12-2005, 07:41 AM   #14
Orson
Member#: 25254
2003 WRX wagon
I just did the Mulder's 2723 bulb modification. Holy cow! That is a big difference.
On a slightly unrelated note, anyone try to open up the Lamco gauge? I want to paint the pointer yellow.
Orson is offline   Reply With Quote
Old 04-12-2005, 08:08 AM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You can open it up, it just takes some time. The metal bezel ring is crimped in place and can be removed by working around the back edge with a small screwdriver, gradually prying it up until it can be slid off from the front. Be careful not to damage the glass face or the bezel itself, and of course try not to slip with the screwdriver and put it through your hand. To reinstall, first make sure the gauge face and glass are perfectly clean, then put everything back in place and re-bend the rear of the bezel to lock it back down.
Old 05-22-2005, 04:20 PM   #16
arc190
Member#: 87689
2004 Impreza WRX STI
Silver/Silver
I don't know about all permanent markers, but Sharpies wear off pretty quick. I colored my HVAC bulbs red and started noticing them slowly changing to pink within a couple weeks. The condoms should work good, but it's kind of discouraging that it costs less than $2 to buy them, but after tax and shipping it's $10.
arc190 is offline   Reply With Quote
Old 05-22-2005, 04:26 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
...that's interesting.....my boost/egt have been colored for....well...almost 2 years now.....and still are green enough.....
....mebbe the red isn't as good or the lights are hotter and eat the dye faster.....
Old 05-23-2005, 11:48 PM   #18
writersblock
Member#: 28912
Platinum Silver
I tried this modification with green bulb covers from Parts Express, hoping to match the stock 2002 interior illumination. Unfortunately, it came out too dark. I ordered the brighter bulb as referenced earlier in the thread, as well as several other incandescent bulbs and leds. I'll report back my findings to those who are interested in trying to match their factory interiors.
Writersblock
writersblock is offline   Reply With Quote
Old 07-21-2005, 10:23 PM   #19
bfarm
Member#: 59378
1997 Lincoln Conti
Champagne
Maybe a dumb question here:
Are stock boost gauges in all WRXs on the right of the steering column? I noticed this in your pics.
Because I think STi's are all on the left... mine is (05 STi) and so is this STi one: http://forums.nasioc.com/forums/showthread.php?t=793523
bfarm is offline   Reply With Quote
Old 07-23-2005, 09:02 PM   #20
MU5A5HI
Member#: 61622
2004 WRX PSMCobbStg2
AP Helix U/D KBoySS Tint
My stock 04 WRX has its dealer installed boost gauge on the left side. I think it changed to left instead of right on MY04.. which would explan why all the STi's (USDM anyhow) have it on the left.
MU5A5HI is offline   Reply With Quote
Old 07-23-2005, 10:26 PM   #21
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
it's on the left in my '05 wrx
r0nzar is offline   Reply With Quote
Old 07-25-2005, 10:20 PM   #22
MU5A5HI
Member#: 61622
Just did the mod today. Thanks for the awesome writeup trunk_monkey. I tried months ago for a long time and could not figure out how to get the boost gauge apart.. yet it was so easy with the instructions. Looks very nice. I got the 2723 bulb and put 2 red bulb covers on it.
Old 07-25-2005, 10:37 PM   #23
bfarm
Member#: 59378
1997 Lincoln Conti
Champagne
Ah I understand now about the boost location. Thanks for clarifying.
The gauge in my STi definitely blocks the outside temp reading pretty well. It blocked it thoroughly enough that I didn't notice it until I read through the manual entirely and read about it
Old 07-27-2005, 12:05 AM   #24
beastSTI
Member#: 87633
2005 Impreza WRX STI
This is one mod I gotta do.
beastSTI is offline   Reply With Quote
Old 07-27-2005, 10:06 AM   #25
MU5A5HI
Member#: 61622
If you are like me and have STi gauges in a regular WRX, blocking the 'outside temp' reading is a good 'feature'.. since i dont have an outside temp sensor, and the reading is always wrong. Yesterday it said 42 degrees all day and it was like 90. I was wishing for 42
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 770 05-24-2016 03:24 PM
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 249 05-24-2016 03:23 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 72 04-21-2016 04:22 AM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 02:52 AM
Has anyone tried to change the OEM boost gauge face? Undepelo Interior & Exterior Modification 11 01-05-2005 05:41 PM
