Old 07-28-2005, 12:38 AM   #26
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
how different would it be if you have the factory gauge pod? where do i get a 2723 bulb from? i remember when i had an autometer, i could use different wedge bulbs
AK_2002_WRX is offline   Reply With Quote
Old 07-29-2005, 03:16 AM   #27
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Can someone take pics of the stock bulb and the brighter bulb? Just want to see if it's really worth changing the bulb for .2 watts of light?
Same question as above, where can this bulb be had?
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 08-23-2005, 12:14 AM   #28
ILSMKU2
Member#: 77908
2011 E92 ///M3
RIP 11, 09, 06, 03 STI's
Default 2.3W is much better
Thanks,
-Nigel
I dont have pics to show you, but I first colored my boost gauge light with a sharpie and it was rather pink. I then got the 2.3w bulb and it was MUCH brighter, but the sharpie didnt hold well. I then got some red covers on the 2.3w bulb and its a NICE clear RED. Not pink, not red washed out, pure bright red!
The bulb can be found at your local pepboys, kragen, and radioshack. If you pull the bulb from your boost gauge, you will see it clearly marked "74" somewhere on it. Take that into the auto parts store and look around. You will see normal 2.1w #74 lights and you will also see a 2.3w version (not sure if its still called a #74), but I found them at two different stores.
I also heard you can use a #24 bulb, which is bigger in size, but Im not sure on that.
And finally, the LED ones do work well color wise (speaking about boost gauge only), but I found the lighting to be pointed towards the top of the gauge only.
My suggestion, do LED for the speedo gauge cluster, do the 2.3w #74 light for the boost. And the HVAC, I dont know much about what looks best.
ILSMKU2 is offline   Reply With Quote
Old 12-10-2005, 06:50 AM   #29
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
i did the ghetto mod and used a red sharpie. looks great, but i would like the look of LEDs, which ones fit an 05? when i took the gauges out, they were little bulbs, i thought they would be bigger wedge bulbs, kinda like what autometer uses.
Old 08-11-2006, 03:49 AM   #30
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Originally Posted by Mulder
Also I see your gauge doesn't read 0, unfortunately this is very common.
Mine is a tiny bit off 0 when idling. What should it be at when the engine is off? Mine is around -.75
0BlueSTi4 is offline   Reply With Quote
Old 08-11-2006, 04:05 AM   #31
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Ok so sounds like to better match STi gauge cluster you would use a brighter bulb and single? (or did you use more than one?) red bulb cover.
Has anyone experimented with brighter bulbs and different number of red bulb covers for the key ring and HVAC? I am just trying to make everything match the stock STi cluster as closely as possible. Any tips would be greatly appreciated!
Thanks!
Old 08-11-2006, 05:53 PM   #32
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Originally Posted by IntraWRX
Scotty, was wondering if blue sharpie would end up looking teal like the condoms do? or do they look bluer than condoms?
Thanks!
I used blue sharpie for door step lights in my old honda accord and it did look teal. At first it would look fairly nice and blue but within a few days to a week it would start to fade and look teal. Within a month or two they would look almost clear again so I would have to keep painting them over and over.
Old 08-29-2006, 01:49 PM   #33
Pain++
Member#: 88289
2006 WRX: Stage 2
Urine-soaked Subway Car
What is the likelyhood that the '06 WRX factory gague has the LED rather than the bulb? I'd like to do this, but I'm afraid that I'll have the LED due to it being newer, as the first post suggested....
Pain++ is offline   Reply With Quote
Old 10-03-2006, 03:09 AM   #34
andy1256j
Member#: 89938
2004 WRX Sedan
Java Black Pearl
I really have a stupid question, but I really never knew what the "MY" in posts that have "MY04" for example, meant?
Does anyone know, I'm pretty sure someone does.
andy1256j is offline   Reply With Quote
Old 10-03-2006, 02:35 PM   #35
lmbmusic
Member#: 98932
2010 OBP OBS
MY = Model Year and definitely wrong thread to post this question in
lmbmusic is offline   Reply With Quote
Old 10-11-2006, 06:45 PM   #36
Paradenu
Member#: 110037
2005 STI
Well, I tried this out on my '06 STI today and it looks like I have the LEDs.
....Just a heads up to any '06 STI owners wanting to do this.
Paradenu is offline   Reply With Quote
Old 10-12-2006, 08:51 PM   #37
sauuce
Member#: 109253
2006 STi
SGM
thanks for the heads up..i guess i shouldnt have gotten the boost guage option :T
sauuce is offline   Reply With Quote
Old 01-22-2007, 07:24 PM   #38
thejean
Member#: 17763
Originally Posted by writersblock View Post
I tried this modification with green bulb covers from Parts Express, hoping to match the stock 2002 interior illumination. Unfortunately, it came out too dark. I ordered the brighter bulb as referenced earlier in the thread, as well as several other incandescent bulbs and leds. I'll report back my findings to those who are interested in trying to match their factory interiors.
Writersblock
Anything to report back?
thejean is offline   Reply With Quote
Old 02-20-2007, 06:02 PM   #39
ElCuRaNdEr
Member#: 138747
partsexpress doesn't carry the bulb covers anymore...does anyone know who else does?
ElCuRaNdEr is offline   Reply With Quote
Old 02-23-2007, 04:18 AM   #40
MERT K
Member#: 81807
07 WRX STi
Urban Grey & wingless
i have an 07 sti... im not even going to try to change mine... im sure its led
MERT K is offline   Reply With Quote
Old 02-23-2007, 11:51 AM   #41
loudaccord
Member#: 99489
The Black Pearl
Yarr!!
has anyone with the 06+ changed the led in the boost gauge?
loudaccord is offline   Reply With Quote
Old 04-02-2007, 11:38 PM   #42
RugDoc2003
Member#: 3628
2005 Impreza WRX STi
grey
I just did this mod and it worked out great. One thing that you may want to try is instead of prying the boost gauge out of the housing... see if you can used the hose/wiring in the back to push it out...
Worked for me and saved me a lot of hassle...
now onto the keyring... which isn't nearly as easy on my MY05 STi
-rug
RugDoc2003 is offline   Reply With Quote
Old 05-02-2007, 01:13 AM   #43
biker921
Member#: 118236
Must be a thing on all the new WRX/STi's cause I tried on mine and got the same result. Does anyone know of a solution?
biker921 is offline   Reply With Quote
Old 05-05-2007, 01:37 AM   #44
biker921
Member#: 118236
Suck!
Old 05-11-2007, 05:01 PM   #45
GrassyKnoll
Member#: 111702
2004 WRX STI
Just to clarify > I did find them on parts express http://www.partsexpress.com/webpage....TOKEN=32012139
GrassyKnoll is offline   Reply With Quote
Old 06-28-2007, 10:25 AM   #46
biker921
Member#: 118236
Anyone know what size bulb the cig lighter bulb is? Is it a .12 or .2?
Old 05-12-2008, 04:31 PM   #47
efaroh
Member#: 166947
2006 WRX Sedan
Crystal Gray Metallic
bringin it back to life! thats the way it looks like on the back of mine. i got the boost gauge off of a 06/07 sti. anyone try opening it up and change the LED?
efaroh is offline   Reply With Quote
Old 05-13-2008, 03:58 AM   #48
efaroh
Member#: 166947
2006 WRX Sedan
luckily my buddy had an older model boost gauge laying around thinking it was broke but it was just a burnt bulb.
I used bulb 2723 and colored it using a fairly new green sharpie.
i turn it on and it looked like a nasty teal color.
so i put the blue condom over it and it comes pretty close to an exact match of the wrx green interior color.
overall i'm satisfied, but i wish it would match the stock interior even closer. maybe a green condom would do the trick?
pic
Old 05-13-2008, 04:08 PM   #49
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
i opened it up...i didn't see anything that looked like an LED or bulb...what the heck?
if there is one, it's super small and sits under this yellow foam piece...
Tahoe SC is offline   Reply With Quote
Old 05-14-2008, 04:10 AM   #50
efaroh
Member#: 166947
2006 WRX Sedan
so what youre saying is even if you open it up there is no way to replace the bulb for the new gen boost gauges?
Interior Color Change Tutorial: Gauge Cluster Trunk_Monkey Electrical & Lighting 768 05-20-2015 04:45 PM
Interior Color Change Tutorial: Key Ring Trunk_Monkey Electrical & Lighting 71 03-02-2015 05:42 PM
Interior Color Change Tutorial: Radio and HVAC Trunk_Monkey Interior & Exterior Modification 248 10-29-2013 12:47 PM
Interior color change tutorial: Clock WejR20X Electrical & Lighting 9 11-07-2006 03:52 AM
Has anyone tried to change the OEM boost gauge face? Undepelo Interior & Exterior Modification 11 01-05-2005 06:41 PM
