Old 04-02-2005, 11:23 PM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default 1.8 idleing running rich problem
I have a friend how has a 95 impreza L with a 1.8 motor from a 93 running the 93 ECU. Its an automatic and it wont pass emissions. its running rich and has a brand new cat and 02 sensor. the idle will jump and it will want to idle at around 200rpms.
could it be possible that its a valcum leak? what else should I look into?
scobaru is offline   Reply With Quote
Old 04-02-2005, 11:54 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
has he had his obd-I codes pulled?...maybe vacuum leak, also check the MAF sensor...see if it is clean and still good
Old 04-07-2005, 03:05 PM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
update I could still use some help the car idles fine just rough no codes the MAF sensor is clean. the idle does'nt jump. it runs crazy rich fuel pressure is about 28psi which is what I checked to be correct the fuel pressure regulator is getting valcum that was checked.
Old 04-07-2005, 04:53 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Is the MAF from the same year as the ECU? It may be getting the wrong signal.
Jay Storm
1.8 idle problem nikesb1111 Normally Aspirated Powertrain 12 06-20-2009 09:31 PM
Erratic idle, running rich RsnSun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-09-2009 04:03 PM
Car won't idle, running rich any suggestions fstwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-27-2007 04:40 PM
Running Rich problem under load. boostedscooby2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-30-2006 09:20 AM
1.8->2.2 rich @ idle question drewdogg Subaru Conversions 1 01-20-2006 12:48 PM
