#1 |
Member#: 36607
Hi all, we'll it finally happened. Got my ECUtek re-flash/dyno tune today at Grouppe-S By Mike W. Dude's awesome. He dyno tuned the Baja and the end result is: 258WHP and 278WTQ @ 16PSI max on the Mustang Dyno (stock STI's registers at 205WHP - 210WHP).
So to sum it up, my upgrade is as follows Random tech exhaust, Helix up-pipe, walbro 342 fuel pump, VF-39, STI TMIC and ECUtek reflash/dyno tune. The baja now drives like a bat out of hell. The pull is smooth as butter. I've never seen my RPM needle sweep so quickly. Again, props to Mike and Grouppe-S. Specailly Mike for working with the ECU tek peeps to develop the correct rom file for my Baja. Here are pics from the dyno tuning: http://pg.photos.yahoo.com/ph/wrxdud...1b.jpg&.src=ph http://pg.photos.yahoo.com/ph/wrxdud...6c.jpg&.src=ph http://pg.photos.yahoo.com/ph/wrxdud...d5.jpg&.src=ph Here's a vid clip of it. Select the Dyno tuning vid clip file. http://f1.pg.briefcase.yahoo.com/bc/...+stuff&.view=l Well, that is it folks. my HP gain expectancy was exceeded by 8WHP and the torque, it's unbelievable considering my stock figure is 180WHP/199WTQ. Wikid ![]()
#2 |
Member#: 14555
Vehicle:1995 L (Apex Tiger) Battle Ready Baja |
Congrats, thats awesome!
#3 |
Member#: 36905
BAIC
Vehicle:2006 Legacy GT Slvr leggtnut on lgt.com |
nice. I whish I could afford to do that. Wikid, you need to join us some monday in Scotts valley.
#4 |
Member#: 11015
Vehicle:'06 Volvo V70R Sonic Blue |
Good stuff!
Would you consider your general setup to advance the Baja-T to stock STI specs or something thereabouts? Now that you have the VF39, TMIC, ECU upgrade, and exhaust, would you have expected to get closer to 290whp? |
#5 |
Member#: 56048
Vehicle:2004 baja turbo 5spd black/dark gray |
very sweet results!
#6 |
Member#: 72014
NESIC
Vehicle:05 Baja gone Winner best wax job 06WBM |
290 whp is crazy he would need to change to a front mounted IC those handle 300+hp which is what the crank would be putting out. I'm not sure what the loss is but let's say 10% it's now 260whp add another 26 on to that (use fuzzy math i'm working backwards here and trig was SOooo long ago) that 285 crank Hp that's 75 over what subbie states it is...
#7 |
Member#: 78643
Vehicle:1995 Chevy S10 4x4 Teal Green |
so was the total out the door cost for this?
#8 |
Member#: 38370
TXIC
#9 | |
Member#: 69477
Vehicle:2006 Evo IX Electric Blue |
#10 | ||||||
Member#: 36607
It's going to be hard to achieve that 290HP on my setup. There is only a little more room for improvement left like maybe adding headers but as it stands, I am very pleased with the results both on dyno and road. You'd have to test drive it to see or feel what I mean. Quote:
for a best case scenario on a stock STI. That means the Baja makes 48 WHP (which is BTW 22.8%) more than the stock STI . How could I have 285 crank HP if a stock STI is 300 crank HP? Not out to get you or anything but I'm just trying to make some sense To sum it up my baja crank HP is 300 +22.8% of 300 = ~370 Does that make sense? Quote:
up-pipe = 179.00 Walbro pump = 100.00 VF-39 = 400.00 Sti TMIC = 350.00 ECUtek and dyno tune = 700.00 Total = $3129.00 and ~80WHP gain which is less of what I spent on my WRX with VF34, XEDE, TXS TMIC, STI injectors, Walbro pump, TXS TBE, TXS uppipe, dyno tune and only made 246WHP/236WTQ on vishnu's dyno. You may be able to save some $ if you custom make a full 3" TBE (Keep in mind, you can use any WRX or STI Up-pipe and downpipe). I just got a real good deal on the STI TMIC and VF39. Wikid Last edited by wikidwrx; 10-10-2005 at 03:42 PM. |
#11 |
Member#: 36905
BAIC
Wikid, I don't think that I will make it to mt hammy, but we are planning on haveing a dirt drive or some tye of weekend run in the santa cruz mountians or something. I will keep you posted on what happens. We have too many people in school and in the same boat as me, just about flat broke.
#12 | |
Member#: 72014
NESIC
#13 |
Member#: 72618
Vehicle:2005 Baja Turbo Garnet Pearl |
Hey Wikid,
That is Awesome! When I got the Baja in October, I promised myself I wasn't going to mod it... I got my up-pipe delivered from Gruppe-S on Saturday... I didn't get a chance to install it this weekend, but I am chompin' at the bit wanting to get it done. |
#14 |
Member#: 56048
on a dyno jet, I believe the Sti dynos 220-225whp. Thats for 300 bhp rating, which is ~25% drivetrain loss. The WRX also supports those drivetrain loss numbers. So 258whp is around 345hp IF it were on a dynojet, but the mustang dynos are often lower, so it could be as you say if an STi does around 205whp on it, then you are about 20whp low, and your baja is in the 365 range.
I know the sti can support 17psi -- have you thought about trying one extra psi boost and see if that helps or hurts your numbers? Either way awesome results. PS my boost gauge still shows me max around 10.5 psi. Maybe ill bring it up next time cars at the dealer although im sure they wont be able to do much about it (or even care) |
#15 |
Member#: 11015
just watched the video clips -- awesome!!
#16 | |||
Member#: 36607
wikid |
#17 | |
Member#: 36607
wikid |
#18 |
Member#: 69477
I would like see 21psi on your set up with A Water/Methanol Injection Kit.
#19 | |
Member#: 36607
anyway just enough to hold my ground against unsuspecting ricers lol! wikid |
#20 | |
Member#: 72618
#21 |
Member#: 11015
we should all admit ourselves at the same time so we can discuss future upgrades.
#22 | |
Member#: 36607
wikid |
#23 | |
Member#: 69477
"I'm happy with it for (NOW)" Did you see the PDX Tuning Dyno Sheets for the 05 Legacy GT Stage1 & 2 upgrades? Your numbers are very close to there Stage2 http://www.pdxtuning.com/technical_legacy_stage1.htm You got a more whp but the torque is right there. I too, made a promise to my wife. I wasn't going to mod the New BAJA and void another warranty. So, wikid, Thank you for bringing me back to my senses. I don't know what I was thinking, making a promise like that. ![]() |
#24 | |
Member#: 36607
wikid |
#25 |
Member#: 5322
NESIC
Vehicle:07im +07Leg+00Forest Scooby wrench turner |
STi4LUNCH
nice job |
| Thread Tools | |
| Display Modes | |
| 07 STI Limited - Simple Stage 2 with Great Results | Equilibrium Tuning | Proven Power Bragging | 66 | 10-11-2007 02:54 PM |
| STI muffler project complete! | dracatero | Texas Impreza Club Forum -- TXIC | 7 | 10-01-2006 10:03 AM |
| Baja turbo simulated road dyno results | Hawk296 | Baja Forum | 18 | 06-16-2006 08:18 PM |
| Udate on my Baja STI project, check it out! | wikidwrx | Baja Forum | 21 | 04-03-2005 08:32 AM |
| Project 2.5 Turbo L Wagon project Complete! | yebokmj | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 07-29-2003 04:27 PM |
