Old 04-03-2005, 10:42 AM   #1
legacyace
Member#: 84364
1997 BG-5
Ones Black and Ones White
Default 4wd to fwd
my legacy has a fuse holder in the engine bay, when a fuse is inserted the drive train is changed from an all wheel drive to front wheel drive.
Doing this i instantly notice power gain and a better fuel average but i have my doubts. does this in any way spoil my drive train.
legacyace is offline   Reply With Quote
Old 04-03-2005, 10:49 AM   #2
Slack
Member#: 17548
I don't think doing for extended periods of time would be good for the car, but I'm not a mechanic. If you want FWD, buy a Honda.
Mick
Slack is offline   Reply With Quote
Old 04-03-2005, 10:56 AM   #3
Section 8
Member#: 821
Your car has a 90/10 torque split until the front wheels slip in the first place. Instead of driving the rear wheels/axles/driveshaft with the center differential you are doing it with the ground. You are spinning the same amout of junk with the fuse in or out.
Section 8 is offline   Reply With Quote
Old 04-03-2005, 11:02 AM   #4
Slack
Member#: 17548
edited for lack of content. Greg, check your pm's.
Mick
Old 04-03-2005, 01:48 PM   #5
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
the FWD mode is only suppost to be used for towing i believe....thats all I know about the subject
scobaru is offline   Reply With Quote
AWD vs 4WD vs FWD vs RWD and all my dumb questions ychan Newbies & FAQs 5 02-26-2003 02:48 PM
How to convert to FWD? djerickd Transmission (AT/MT) & Driveline 16 10-04-2002 05:49 PM
4wd conversion to fwd jezzeppi Transmission (AT/MT) & Driveline 0 12-28-2001 12:34 PM
4wd to FWD smacksube Transmission (AT/MT) & Driveline 35 12-01-2001 02:12 AM
converting 4wd to fwd thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-24-2001 09:27 PM
