Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 07-23-2001, 10:20 PM   #1
silver_rs
Member#: 5832
Default Fuel pump swap
Hi,
I have a MY99 RS, and I heard some people swap their fuel pump (eg RX7 TT). I was wondering, why do people do this ? Is there a performance gain ? If so, does the A/F ratio have to be adjusted with a FPR (Fuel pressure regulator) or an AFC (Air fuel computer) ?
Is this only applicable for turboed Impreza RSs ?
Thanks for any info...
silver_rs is offline   Reply With Quote
Old 07-23-2001, 10:37 PM   #2
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
If you're running N/A your stock fuel pump should be able to supply enough fuel to your injectors. Others with large injectors or RRFPR's have to run a faster pump to supply enough fuel.
GTBGUY is offline   Reply With Quote
Old 07-23-2001, 11:31 PM   #3
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
The turbo guys buy this particular pump since:
- it has a high flow ratio compared to the stock pump,
- it pretty cheap compared to an STI pump
There's some modification to be done on the wiring harness but it's rather minor....
Robin
www.ottawasubaru.com
Robin2 is offline   Reply With Quote
Is the Fuel pump controller necessary for WRX swap? Homemade WRX Subaru Conversions 41 07-05-2011 11:12 AM
fuel pump swap anyone? kheff46 Subaru Conversions 10 05-12-2006 12:16 PM
STi S202 swap, fuel pump running, car off. FJP Subaru Conversions 19 12-23-2003 07:39 PM
Fuel Pump Controller Issue on WRX Swap Zephyr Normally Aspirated with bolt-on Forced Induction Powertrain 12 07-23-2003 10:21 AM
Fuel Pump Swap StevieD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-28-2002 09:47 PM
