Old 04-03-2005, 05:56 PM   #1
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default Ticking / slapping sound coming from engine; help please. W/VIDEO
It seems like every week there is something new that goes wrong with my car and I have to sink further into credit card debt fixing it.
This time; I got the car back from my latest repair (MAF went) and it was running fine. Drove 100 miles with it, then on my drive back I noticed that at partial throttle (10 - 20% to be exact) the engine makes a ticking / slapping sound. It sounds exactly like a lawnmower. It idles fine and does not make any unusual sounds when idling, and it also does not make any unusual sounds when at higher throttle settings. Power appears to be normal. I believe the sound may have started after I drove the car very fast for an extended period of time, but I am not 100% sure.
I made a video of the engine with the hood open and me manually opening the throttle. You can clearly hear the sound I am talking about on the video, and you can also see how the sound goes away when the engine is idling or at WOT.
It will make this sound at any RPM, but only at 10 / 20% throttle, and it has never done this before. The engine is fully warmed up when it does it also.
I have a perma-CEL from my high flow cat. converter, DESPITE the GP Moto rip-off CEL fix, but aside from that I do not believe this is causing any more CELs.
I hope that this is nothing serious and that some of the more knowledgeable members here might be able to help me solve this issue without having to take the car to a dealership because I really can not afford it right now. Thanks guys.
Last edited by powerlabs; 04-04-2005 at 11:58 AM. Reason: Maybe the video will help?
powerlabs is offline   Reply With Quote
Old 04-03-2005, 07:47 PM   #2
Slack
Member#: 17548
Damn! That does not sound good AT ALL. The sound made me cringe. I'm no mechanic, but it sounds like pistons hitting valves. I could be completely wrong, though. I would strongly recommend not driving it any more until you figure it out. I will pm Tim Sanderson to make sure he reads this thread.
Mick
Slack is offline   Reply With Quote
Old 04-03-2005, 07:55 PM   #3
powerlabs
Member#: 45790
SUPERCHARGED
Yeah, it sounds horrible, but I still had to drive it back 100 miles like that. As I said though, it only does it at 10 - 20% throttle, so if I go from no gas to halfway down on the gas pedal, the car sounds normal.
More info on the car that may be relevant: Subaru Impreza 2.5RS 1999, 79000miles, running Mobil 1 synthetic, 2500miles since last oil change. The sound appears to come from either the throttle body or from the passenger side of the engine, but that may just be my impression. Mods are a full exhaust (Borla Headers / random tech high flow cat converter, borla catback), Injen CAI, UD pulley, LW Flywheel, Apexi S-AFC, PLX devices Wideband O2. A/F Ratio is normal when the car makes that sound. The car is driven hard, but it has never made that sound before.
Old 04-03-2005, 07:58 PM   #4
Slack
Member#: 17548
Have you ever had the valves adjusted? Have you replace the timing belt? How about the timing belt tensioner? I know you had an accident in your car a while back...was the timing belt cover cracked or damaged at all?
Mick
Old 04-03-2005, 08:14 PM   #5
powerlabs
Member#: 45790
SUPERCHARGED
Mick
The valve cover on this car has never been off AFAIK. Timing belt replacement is scheduled every 100K miles by Subaru, so I haven't done that yet either. Same for the timing belt tensioner.
As per the repair shop bill it does not seem like there was any damage done to the engine or the timing belt cover. Also, it has been some 10 000miles since my accident and this noise never occured before.
Old 04-04-2005, 04:33 PM   #6
powerlabs
Member#: 45790
SUPERCHARGED
Help? Someone?
Old 04-04-2005, 05:31 PM   #7
Jejunum
Member#: 15773
2011 Impreza WRX
u should get timing belt tensioner replaced and see if that does it. if thats whats wrong it will be visually apparent when replacing it too (so im told)
Jejunum is offline   Reply With Quote
Old 04-04-2005, 05:57 PM   #8
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
I agree with the timing belt theory. Get it replaced and do it quick.
X4 SRT is offline   Reply With Quote
Old 04-04-2005, 06:07 PM   #9
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
I was under the impression RS's were due to have timing belts replaced at 60,000 miles - I'm not an RS owner, but that's what I have heard. Obviously, the owners manual would be a good source, and please correct me as there is a very good chance I'm talking out of my arse.
CirrusWRX is offline   Reply With Quote
Old 04-04-2005, 06:54 PM   #10
DreddRS25
Member#: 51642
2008 WRX
I think it sounds like the Butterfly fluttering in the TB. It seems to react immediately when you get on and off the throttle.
May try revving it for a moment with the airbox off. Have a look at the butterfly while changing the throttle position. (not best idea, but if it is the TB it will be much louder without the airbox) Maybe even just take the back part of the airbox off?
GL!
DreddRS25 is offline   Reply With Quote
Old 04-04-2005, 07:33 PM   #11
Nicklbrso
Member#: 44887
00 GC6
No. The timing belt is scheduled maintenance at 105K miles.
Nicklbrso is offline   Reply With Quote
Old 04-04-2005, 07:39 PM   #12
jamesonc
Member#: 49629
'87 Dodge Ram 50
It could also be something like lifter tick. Is it a loud noise?
jamesonc is offline   Reply With Quote
Old 04-04-2005, 07:56 PM   #13
powerlabs
Member#: 45790
SUPERCHARGED
Check out the video. It is quite loud; makes my engine sound exactly like a push type lawnmower. I don't see how replacing the timing belt would help since the engine only does it at part throttle; if it was a timing issue it would do it at all throttle settings, no?
Old 04-05-2005, 12:50 PM   #14
DreddRS25
Member#: 51642
2008 WRX
Check the exhaust from the bottom of the motor?
Maybe an exhaust leak at the headers?
Old 04-05-2005, 01:12 PM   #15
powerlabs
Member#: 45790
SUPERCHARGED
Only a part throttle though? An exhaust leak would get louder when you applied more throttle, I think; this noise goes away after 20% throttle.
But no, its not the exhaust
Old 04-05-2005, 02:26 PM   #16
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
My computer sucks so I can't hear or see the vid.
Where are you located? How far is that from Milwaukee?
Tim Sanderson is offline   Reply With Quote
Old 04-05-2005, 02:29 PM   #17
powerlabs
Member#: 45790
SUPERCHARGED
Well, it just shows a close up of my engine idling; it sounds normal. Then I give it a little bit of gas and it will start to rev and sound exactly like a push type lawnmower. Giving it more gas makes it rev up and sound normally. It only makes the ticking / slapping / knocking / whatever sound at exactly 10 / 20% throttle position, regardless of gear or speed. The sound seems loudest at the intake.
UP Michigan; about 5 hours south of Milwaukee.
Old 04-05-2005, 03:06 PM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
see your midwest thread for my response
Old 04-05-2005, 06:34 PM   #19
powerlabs
Member#: 45790
SUPERCHARGED
Default Update.
OK, I got the car up on ramps and looked all over it.
No exhaust leaks, no cracks on the exhaust headers, no oil drips or liquids pooling up under the car.
Passenger side heads have a little bit of clear oil around them. I don't think it is a leak.
The sound appears to be louder from the top of the engine. It seems to come from the intake almost.
Still no solutions. Someone must have gone through a similar situation before or know what to do, no?
Old 04-05-2005, 06:38 PM   #20
DreddRS25
Member#: 51642
2008 WRX
GL!
Have you ruled out the TB?
Look inside the TB through the airbox inlet with motor running and watch the butterfly as you change the throttle position.
Old 04-05-2005, 09:09 PM   #21
powerlabs
Member#: 45790
SUPERCHARGED
How can I do that?; if I want to look at my throttle butterfly I will need to disconnect the MAF and the car will not run.
Old 04-06-2005, 07:31 PM   #22
DFL2.5RS
Member#: 73228
2015 White STI
2013 WRX, 2003 Rally car
your car should still run if you have the maf unplugged I believe...
DFL2.5RS is offline   Reply With Quote
Old 04-07-2005, 10:24 AM   #23
DreddRS25
Member#: 51642
2008 WRX
It would help if I looked at the year of your make.
I often forget the difference between a MAF and MAP. Though, I thought the car would run upto 4k rpms without the MAF plugged in. Not sure how easy or necessary that would be, but I would try it (though having a mechanic look at it would be best).
Old 04-07-2005, 11:47 AM   #24
Siper2
Member#: 1134
2010 Legacy GT Ltd.
Timing belt tensioner, perhaps? Mine went at about 65k I think.... replaced the belt while they were at it.
That was a loud, very obvious WHAP WHAP WHAP though. Not much like a lawnmower... unless it was a sick one...
Siper2 is online now   Reply With Quote
Old 04-07-2005, 12:01 PM   #25
John*G
Member#: 19562
95 coupe
red
That does not sound like a timing belt tensioner, I replaced mine. It kind of sounds like a alternator with a bad brush. If you have a piece of tube/pipe, or better yet a stethoscope it may help pin point the source of the noise.
John*G is offline   Reply With Quote
Loud ticking noise coming from motor. Help prestofilipo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 12-17-2011 11:17 PM
Odd sound coming from brake/suspension? Help! Leo has WRX Brakes, Steering & Suspension 0 06-15-2008 03:19 AM
Knocking sound coming from passenger front...help EL CABRON Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-01-2008 10:27 AM
Ticking? Rattling Sound coming from rear of car??! enXiks Newbies & FAQs 3 08-24-2006 07:59 AM
help! sound coming from front right tire dodichi Brakes, Steering & Suspension 3 05-28-2001 08:54 PM
