Old 04-03-2005, 10:22 PM   #1
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Default NOOB comp & AP question
Ok I want to start out by saying im having 2 problems with my AP.
1) I have a HP pavilion ze5400 laptop with no 9 pin connector. I wondering what i need to do in order to get the AP to synce with me PC.
2) Im running a Stage 1 93oct map that was on the AP( no idea which version it is) and im not getting above 13psi. I flashed the "stock" base map an i could hit 13.5psi all day.
I think that with fixing the PC synce problem fixed the boost problem will be fix quickly. Any advise or help would be amazing. Thanks!!!
line is offline   Reply With Quote
Old 04-03-2005, 11:18 PM   #2
criz
Member#: 56497
2008 WRX STi
dude, just run the STG 1 01 oct HGW and you'll hit those targets!
I did that with my stage 2 map on the sti
criz is offline   Reply With Quote
Old 04-04-2005, 12:39 AM   #3
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Im going to run that map but i need to find out how to have my AP and comp synce to run that map. Anyone have any ideas on how get this to work???
Old 04-04-2005, 12:54 AM   #4
jmolaver
Member#: 19130
'01 TTE Miata
www.awesom-oracing.com
line if your computer does not have a serial port you may be able to pick up a USB to serial adapter at a local computer shop (compusa, microcenter, etc) and try connecting it that way.
jmolaver is offline   Reply With Quote
Old 04-04-2005, 01:02 PM   #5
line
Member#: 76189
WRX: Parking Lot
Racer in Training
I did try that but the AP doesnt know that the USB device is the AP. I was hoping that someone else on the board has over come this problem before.
Old 04-04-2005, 02:43 PM   #6
jmolaver
Member#: 19130
'01 TTE Miata
sorry, i don't actually have one, i was just throwing that out as a possibility
i'd email cobb and see if they have any suggestions..
Old 04-04-2005, 10:15 PM   #7
seattle944t
Member#: 18308
2005 WRX STi
The USB device should create a COM port - that is what the accessport and the map manger software is looking for. You need to go into the 'configure communications' in the map manger software and select the new COM port the USB-Serial device creates.
seattle944t is offline   Reply With Quote
Old 04-05-2005, 01:01 AM   #8
line
Member#: 76189
WRX: Parking Lot
Racer in Training
thanks ill have to give it a try again.
nOOb AP question betnic Engine Management & Tuning 1 08-26-2006 12:08 PM
noob AP question about changing map versions ScoobySnacker AccessPort 4 08-02-2006 11:53 PM
Yet another noob AP question (groan) KeyPirate AccessPort 2 03-22-2006 04:17 PM
Noob AP question about 04' 05' ECU's M8 Engine Management & Tuning 11 06-19-2005 10:36 PM
Cobb-APS, Vishnu, & TXS questions from noob Ag. Newbies & FAQs 2 06-28-2002 04:15 PM
