Old 04-04-2005, 01:26 AM   #1
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
Default wrx motor build up questions
ok, i there is a kid i know that has a 02 wrx motor all taken apart sitting in his garage that he will give me for free. when it was takent out of the car the rod bearing had a bunch of play in it and it was swiched out for a 20g closed deck block.
the block halves are seprated and the pistons rods and everything are sitting in a box, i didnt see a crankshaft in there though.
being that its open deck im wary of building it because i would be putting all new forged internals (pistons crank and rods) he doesnt have heads but the heads that came off his 20g block i can get for 200 bucks. the internals will cost the most.
so how strong is this block? from what ive seen places like axis dont even use this block, they instead use turbo legacy and sti semi closed deck blocks.
along with internals i will need a new intake manifold, fuel rails and injectors. if the bolt patterns are the same ill probaly go with a 97 legacy NA manifold with topfeeds or get a manifold that has the same bolt pattern and do a dual plennum dual throttle body but that may be too much.
i already have a set of headders and a turbo that are sitting around so thats covered.
in couclusion. is this block worth it to build? where can i get all the internal parts for cheap? where adn which intake manifolds and fuel systems should i look at? is there anything that i missed in my evaulation of the situation?
if all else fails i could build a pretty bitchin coffe table.
azn2yunr is offline   Reply With Quote
Old 04-04-2005, 02:19 AM   #2
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I'd say build a bitchin coffee table.
Or reinforce the block. You're going to spend a fair amount of money building up the block and you'll need to assess your goals. Maybe a used V7 block (I've seen them pop up for around $800-$1000) would be stronger and cheaper. Or you could get the desired power from a stock EJ257. I saw a few on ebay last week for $1300 and no one was bidding on them.
I wouldn't start with a EJ205 block unless you're planning on using a very small turbo.
Pete
eastcoastbumps is offline   Reply With Quote
Old 04-04-2005, 04:07 AM   #3
azn2yunr
Member#: 67229
9295 BC/gm6
i was orignaly thinking of using a 22t but this block is free so i thought id consider it. i was going to buy a new (at least to me) 22t shortblock and build it up and if all else fails use the one in my car when and if i get a new car.
power goals are something in the 600-750 wheel range with a 9500+rev limit using a sequential vf-x and a gt-x or something of that nature. its a long build so using my block is a last resort. that and i wanted the entire motor to be coated so starting with the block disassembled is an advantage there
Old 04-04-2005, 05:39 PM   #4
azn2yunr
Member#: 67229
9295 BC/gm6
09 WRX Wagon Build-Up Questions senni18 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-30-2009 02:48 AM
few questions about motor build up. thebasicnecessities Built Motor Discussion 2 04-25-2008 06:02 AM
99RS 2.5L stock motor build up questions. chrismindless Normally Aspirated Powertrain 3 04-21-2005 04:27 PM
Questions on ej25 motor build up SCOOBYLOVER Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-05-2002 02:37 PM
('93-'01) new motor build up nico posteraro Impreza Forum 1 04-16-2001 09:37 PM
