Old 04-04-2005, 12:49 AM   #1
revhigh96
Member#: 60023
Default looking for a swaybar for my 97 2.5 gt sedan
I was looking around for a new rear sway bar. I found the IPD adjustable rear bar but is listed for the outback only. I was wondering if it also fit the sedan. What are my other options for a rear sway bar and maybe even a front.
Along those same lines, I am just starting to modify my 2.5gt. What other upgrades should I start with besides sway bars and short shifter? I have lists of things that I would like to eventually do but what would be the most effective upgrades to start with?
Thanks
revhigh96 is offline   Reply With Quote
Old 04-04-2005, 02:03 AM   #2
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I've enjoyed my whiteline adjustable rear swaybar.
I'm also probably one of the few on this board to have a front whiteline swaybar.
I've had good luck with PDM Racing.
http://www.pdm-racing.com/
Some lowering springs help quite a bit.
I think with the Legacy any handling or braking mods you'll get more enjoyment for your money first.
Kraziken is offline   Reply With Quote
Old 04-04-2005, 01:09 PM   #3
Bakergtt
Member#: 59207
'05 X was 98 LGTT
IPD does offer them for the sedan cuz im going to be getting some. They have been on back order for about a month but as i was told they should be out this week or next.
Rio
Bakergtt is offline   Reply With Quote
Old 04-04-2005, 02:50 PM   #4
dalemcc
Member#: 42821
2006 Legacy 2.5i SE
2002 Legacy GT
I have an IPD swaybar on my 02 gt sedan. Its been great... Until this spring, it started squeaking. I think i just have to re-lube it, but before i do i'm going to buy some new end-links.
dalemcc is offline   Reply With Quote
Old 04-04-2005, 04:07 PM   #5
revhigh96
Member#: 60023
Is there a reason you are looking for new endlinks over the IPD ones?
Old 04-05-2005, 02:28 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I, too, have the Whiteline adjustable rear and the Whiteline 20mm front and I'm very happy with them. I honestly don't think the front bar is all that necessary unless you've done just about everything else with the suspension first, but since I have it's worth it for me.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-05-2005, 03:57 PM   #7
dalemcc
Member#: 42821
2006 Legacy 2.5i SE
2002 Legacy GT
Legacy
revhigh96 - No, i would love to get the perrin end-links from IPD. The problem is, when I put on the bar i must not have used the right allen key to tighten the end-links and ended up stripping it... So now there not tight enough
I justwaiting untill after my wedding to get them
need a new motor for my 97 2.5 GT Legacy mobalegacy Private 'Wanted' Classifieds 2 12-27-2009 03:16 PM
Any difference between a 97 2.5 gt and a 98 2.5 gt Polskino Legacy Forum 3 12-21-2003 07:51 PM
Looking at a 97 2.5 GT 80mgb Legacy Forum 1 03-07-2002 04:33 PM
what can i do to my legacy 2.5 gt sedan canesx1 Legacy Forum 15 07-07-2001 02:17 PM
Newbie looking for info on Legacy 2.5 GT sedan... Eriksport Legacy Forum 21 04-17-2001 11:28 PM
