Old 04-04-2005, 04:29 AM   #1
kickitjp
Member#: 60035
Chapter/Region: PRSIC
Default What's the diff between DOHC EJ25 and SOHC
What's the difference between the DOHC EJ25 (98 RS) and the SOHC (99+ RS)?
...obviously one is dual and the other is single...but what else?
kickitjp is offline   Reply With Quote
Old 04-04-2005, 04:35 AM   #2
TurboReXx007
Member#: 84148
2005 Wrx
black
http://forums.nasioc.com/forums/show...ight=dohc+sohc
You should find you anwser somewhere here
TurboReXx007 is offline   Reply With Quote
Old 04-04-2005, 04:47 AM   #3
kickitjp
Member#: 60035
Thanks for the crosslink, but I was the #6 poster in that thread and no it does not answer my question.
What I'm really trying to find out is why Subaru made the EJ25 in a MY98 RS a
DOHC engine, and all years after that a SOHC EJ25?
Are we seeing any performance differences?
Old 04-04-2005, 09:52 AM   #4
kickitjp
Member#: 60035
I know you guys know bump.
Old 04-04-2005, 11:11 AM   #5
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
kickitjp - one of the main reason for the switch from DOHC to SOHC for the EJ25 was due to the fact that the SOHC is slightly lighter weight, and offered more mid-range torque compared to the EJ25 DOHC motor. The EJ25 DOHC's tend to make more power higher up in the rev band.
GTBGUY is offline   Reply With Quote
Old 04-04-2005, 12:56 PM   #6
kickitjp
Member#: 60035
You the man. Thanks!
Old 04-04-2005, 10:28 PM   #7
cstratton04
Member#: 84489
2005 Toyota Corolla
2005 CBR600rr
I read in the faq that the DOHC was "stronger" and the SOHC was "weaker". Are we talking about the crank, block or what? What is going to react better to mods and which engine is recommended?
cstratton04 is offline   Reply With Quote
Old 04-05-2005, 04:47 PM   #8
Siper2
Member#: 1134
2007 BMW 328xi wagon
Actually, cstratton, I've always read the opposite: that the DOHC engine had some reliability issues, thus they switched (back) to SOHC.
Now I'm sure that's not the whole reason, but...........
Siper2 is offline   Reply With Quote
Old 04-05-2005, 08:52 PM   #9
cstratton04
Member#: 84489
2005 Toyota Corolla
2005 CBR600rr
In the faq it says:
" DOHC 2.5L MAF Based (very strong)"
"change SOHC 2.5L MAF Based (very weak)"
Reliability could be different from engine strength though, so that may be the reason.
Old 04-05-2005, 09:32 PM   #10
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default Some data.
The weak / strong reference on the FAQ is about the MAF sensor those engines used and their tendency to break or not. It doesn't refer to the block.
The SOHC engine offers:
- More torque at part throttle
- More mid end torque
- Higher torque peak (by 4 ft/lbs)
- Less components, lower weight, easier to manufacture.
DOHC offers:
- HP doesn't drop off as fast after it peaks.
1998 DOHC Engine:
Horsepower: 165 @ 5600 pm
Torque: 162 @ 4000 rpm
1999 SOHC Engine:
Horsepower: 165HP @ 5600 RPM
Torque: 166ft/lbs @ 4000RPM
Last edited by powerlabs; 04-06-2005 at 05:05 PM. Reason: Pulled up some numbers for both engines.
powerlabs is offline   Reply With Quote
Old 04-05-2005, 09:47 PM   #11
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
that is waht i was going to say, also one has one cam SOHC and the other has two cams DOHC..
allsubaru83 is offline   Reply With Quote
Old 04-05-2005, 10:53 PM   #12
marc l
Member#: 84592
2003 impreza WRX
yellow
i have a 99 rs with the sohc motor and was wondering if the it would be better performance wise to get a set of dohc heads on it. in a NA performance build up would that be better?
marc l is offline   Reply With Quote
Old 04-05-2005, 11:56 PM   #13
Hawk296
Member#: 14555
1995 Impreza L
Baja
- Higher torque peak (by 1 ft/lbs)
DOHC offers:
- HP peaks at a higher RPM and doesn't drop off as fast.
exactly! cheaper to produce is a large reason they switched over. THey could make the engine perform better and feel more powerful for cheaper.
Hawk296 is offline   Reply With Quote
Old 04-06-2005, 01:58 AM   #14
kickitjp
Member#: 60035
Thanks for the answers.
Old 04-06-2005, 04:35 PM   #15
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
So the DOHC, powerwise, is actually better? And what's this about it being "stronger?" When we say strong, we mean mechanically, right? We're not counting the crappy head gaskets?
Al_Smokemcrack is offline   Reply With Quote
Old 04-06-2005, 05:04 PM   #16
powerlabs
Member#: 45790
SUPERCHARGED
Did you bother to read my response?
1998 DOHC Engine:
1999 SOHC Engine:
Old 04-06-2005, 09:32 PM   #17
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Ooooooh. I'm sorry. I must have skipped right over that one.
Old 04-06-2005, 10:34 PM   #18
Jesse00
Member#: 78036
02 Impreza 2.5TS
Midnight Blue
Not only is it cheaper to produce, its also cheaper to maintaince as there are less parts to it than DOHC
Jesse00 is offline   Reply With Quote
Old 04-07-2005, 12:40 AM   #19
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
And no stupid shims! Yay easy to adjust valvetrain!
What's the diff. between "C" rear endlinks and straight ones? WRXislander Brakes, Steering & Suspension 2 08-11-2007 02:10 AM
What's the diff. between DMS 40 and 50mm adjustables? Yasin Brakes, Steering & Suspension 3 11-13-2002 05:50 PM
DBASteve.. what's the diff between 02/03 front brake? TerenceT Brakes, Steering & Suspension 1 08-23-2002 04:12 PM
what's the diff between lower tie bar and sway bar? Langit Brakes, Steering & Suspension 5 10-04-2001 05:35 PM
What's the diff. between turbo-back and cat-back exhaust? Buttsy Newbies & FAQs 2 06-23-2001 09:38 AM
