Old 04-04-2005, 04:51 PM   #1
Ft_Laud_wrx
Member#: 32405
2014 BMW M235i
Dinan
Default AP noobie help
My ap for my my02 wrx 5spd was shipped t day and i have a few questions about the setup. I will be loading in the stg2 base map. What I dont understand is once I load this base map in am i good to go or do i load the realtime stg2 map into the ecu after laoding the base map. Can somebody clarify this for me who has experience with this. thanks for the help guys.....
Josh
Ft_Laud_wrx is offline   Reply With Quote
Old 04-04-2005, 05:29 PM   #2
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
not sure if it's absolutely necessary to run the realtime stg 2 map, but it only takes a few seconds to flash the realtime over the basemap. might as well, just to play it safe. have fun!
chewbakarox is offline   Reply With Quote
Old 04-04-2005, 05:46 PM   #3
boostin04
Member#: 54744
2006 Subaru STI
Your basemap is what the AP is going to flash your ECU to (even if you reset your ECU). You dont need anything else, just your basemap. Although Cobb does recommend that you put your basemap to whatever stage it is you are running and not the realtime map...hope this helps, good luck and have fun !
boostin04 is offline   Reply With Quote
Old 04-04-2005, 05:50 PM   #4
WRC-Go
Member#: 29917
2003 WRXWgn-WRB sold
EVO IX-MR, 98 Viper
I don't know of any reason to run a real-time version of the same base map...
Real time maps are to change something from the base version, like valet mode, or economy mode. I don't think real time map learns like the base map - someone else can chime in here, but can't see any advantage to doubling up the mapping...
WRC-Go is offline   Reply With Quote
Old 04-04-2005, 05:59 PM   #5
Slowpoke
Member#: 19879
2004 WRX
Java Black
Yes, you are good to go once you load a base map.
Slowpoke is offline   Reply With Quote
Old 04-04-2005, 06:13 PM   #6
Ft_Laud_wrx
Member#: 32405
2014 BMW M235i
Dinan
Thanks guys. I cant wait to get this thing
Old 04-04-2005, 06:37 PM   #7
not a sho
Member#: 82637
2004 wrx wagon
the only time you need the same real time map as base is if you flashed a economy,anti theft etc. over your original base map.
that is how you remove the flashed economy,anti theft etc.
when you originally flash the base it automatically becomes your real time,until
you flash another real time .
you also can re-set the ecu by pulling the neg.terminal off the battery.the realtime maps you flashed will be removed.and you will now be running the same realtime map as base.
not a sho is offline   Reply With Quote
Old 04-04-2005, 06:56 PM   #8
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Pulling the negative terminal will definately remove the realtime maps, along with any learning that was done be the ECU. Reflashing the correct realtime map to get out of economy or valet however, does not undo any learning done by the ECU. The ECU however will starting learning whatever map you are running so if you run the economy map for a long time and want to switch back to the stg2 map, it may be best to do a reset vishnu style.
phantomsr is offline   Reply With Quote
Snowboarding noobie .. Help! Dragonbreak North West Impreza Club Forum -- NWIC 109 02-14-2008 03:02 AM
Desperate for Help with Cobb AP.. Please help Flyguy3663 Engine Management & Tuning 5 10-08-2005 04:14 PM
AP noob help stisp33d Engine Management & Tuning 5 02-12-2005 02:08 PM
Bethlehem/A-town/Easton Area '02 WRX COBB AP owners: Help gottafly Tri-State Area Forum 12 10-04-2004 08:14 PM
Noobie Help... SilverSpool Texas Impreza Club Forum -- TXIC 65 04-12-2004 06:06 PM
