Old 04-04-2005, 09:13 PM   #1
Nytmare
Member#: 64175
Default Conflicting information...18x8" +35mm on STi...
Okay guys I've been reading/calling a bunch of different places about this and I'm getting mixed answers. Two places have said this will fit fine, and another two have said the wheels would stick out too far. I'm looking at 18x8 Enkei ZR1's for my STi, they've got a 35mm offset which Gruppe-S says will fit over the STi brembo's, but I'm worried about them sticking out too far.
I HAVE searched, but I don't have a large enough grasp on the concepts of offsets and things like that to be able to accurately interpret everything that's said througout the forums. Any input would be greatly appreciated. Thanks guys!
-James
Nytmare is offline   Reply With Quote
Old 04-05-2005, 08:05 AM   #2
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Offset is the difference between the center of the wheel and the mounting surface (hub) where it bolts up to the car. Subaru has a rather unique offset, designed to support the boxer engine. It is recommended that you DO NOT go below 48+ offset for most applications. The wheels you are suggesting would be risky. I would look elsewhere.
conker69 is offline   Reply With Quote
Old 04-05-2005, 11:19 AM   #3
subieworx
Member#: 47769
Those wheels would very close to the fender. They would not fit without rolling the fender and then you would have the problem of possible premature wheel bearing failure.
subieworx is offline   Reply With Quote
Old 04-05-2005, 11:22 AM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
they would stick out past the fender .....
Old 06-08-2005, 10:55 PM   #5
davidbreadon
Member#: 88693
Don't worry about the bearing failure. I know many people that run below +40 offset on the WRX, and have had no problems. In fact I don't think you will find any posts on any Subaru forum that actually tells you that someone was running a lower offset and had bearing failure.
D
davidbreadon is offline   Reply With Quote
Old 06-09-2005, 12:37 AM   #6
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
D
Hehe, I'll let you know if my Gramlights 18x8 +40 killed wheel bearing.
wrx2 is offline   Reply With Quote
Old 06-09-2005, 01:08 AM   #7
LukeWRX
Member#: 32455
2004 STi
WR Blue Pearl/silver
I posted a similar question a couple days ago, regarding 5-Zigen fn01-RC 17x8's w/ +35mm offset. I know of many who have these wheels, and when I posted my question about the offset I got mixed reviews as well.
They obviously did not stick out past the fender from all the pictures I saw, my only question was on the wheel bearing failure.
LukeWRX is offline   Reply With Quote
Old 06-09-2005, 10:27 AM   #8
XT6Wagon
Member#: 524
04 STi
Just say no. They will definitely stick out too far unless you run narrow tires, and then whats the point. Get proper offset rims.
XT6Wagon is offline   Reply With Quote
Old 06-09-2005, 12:15 PM   #9
MinesFaster
Member#: 44503
2006 Evo 840whp/E85
66 Chevelle, 468bbc/600hp
They dont either stick out to far. In fact et40 18x8 stick out right up to the fender edge filling out the widebody. Know facts before you give opinions. I have pics of 18x8 et40 Verdicts underneath my 2002 if anyone wants to host them. On a bug eye I had to roll the fenders some, but that was because I am lowered 2.25" and like to haul people. On an STi, you might get away with it.
MinesFaster is offline   Reply With Quote
Old 06-09-2005, 12:32 PM   #10
LukeWRX
Member#: 32455
2004 STi
I think the real question for STi owners is:
The 17x8 +48mm wheel is offered for the Impreza Sedan, and the +35mm wheel is listed for the STi. Will the +48mm clear the brembo's? anyone using them?
Old 06-09-2005, 12:41 PM   #11
davidbreadon
Member#: 88693
Hey, minesfaster. any problems with the bearings? How long have you run the +40 offset. I talked with you on the other post. I know of no one who has had a problem with a low offset. What are these people talking about? I run a +42 and am still going strong.
Old 06-09-2005, 02:36 PM   #12
UltimateLurker
Member#: 82488
06 Lotus Exige
Your current 17X8 is +53, the 18X8 at +35 is sticking out towards the fender another 18mm (.7"). Stop asking everyone questions, go outside and measure the distance from the outer lip of the wheel to the inside of the quarter panel and you'll have your answer.
I'm going to say it won't fit without some sort of modification, and it will certainly be harder on your wheel bearings.
UltimateLurker is offline   Reply With Quote
Conflicting Information cmichael00 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-20-2008 04:36 PM
Conflicting information about cobb springs, can you clarify? Neiliux Newbies & FAQs 21 07-24-2008 11:54 PM
Conflicting Information WhiteH2O Legacy Forum 31 05-02-2008 11:30 PM
Conflicting information about '04 shocks, need help please! Soon2BRex Brakes, Steering & Suspension 2 04-02-2004 06:46 AM
18x8" SSR Comp on STI w/spacers? GTR STI Tire & Wheel 15 10-31-2003 09:21 AM
