Old 04-20-2005, 04:53 AM   #1
randomthoughts
Member#: 71810
05 Evo 8
Default Accessport problems
so heres the deal got the accessport an loaded up stage 2 93 oct ok well i only hit like maybe 10 or 13 psi in first and second only hit the target boost of llike 15.8 in fourth what should i do: i would try the hwy version but it says use at your own risk this is my daily driver and by the way does anyone else have probs hiting boost in first with or without the accessport..
thanks
randomthoughts is offline   Reply With Quote
Old 04-20-2005, 08:36 AM   #2
WRC-Go
Member#: 29917
2003 WRXWgn-WRB sold
EVO IX-MR, 98 Viper
I'm only running stage one, but NEVER hit close to target in first or second either for that matter. I start getting close to target in third, then hit it in fourth... fwiw.
WRC-Go is offline   Reply With Quote
Old 04-20-2005, 09:03 AM   #3
WRexxer
Member#: 48527
2004 Subaru WRX WRB
COBB VF30
I dont think you suppose to hit target boost in first!! just not enought time and load!
but you're lucky I don't even hit target boost in 5th!
WRexxer is offline   Reply With Quote
Old 04-20-2005, 09:41 AM   #4
TechnoRex
Member#: 66337
2004 WRX Wagon
WRexxer is right - you'll never see target boost in 1&2 and rarely in 3 - there simply isn't enough engine load to produce that kind of boost. It sounds like by 4th you're doing O.K. - target boost for STG 2 is 16psi +- .5.
TechnoRex is offline   Reply With Quote
Old 04-20-2005, 09:46 AM   #5
draggin wagon04
Member#: 39474
form er WRXwag owner
Integra GSR 4-door
HWG is a wastegate thing designed to remedy what the ecu has learned from people running MBC's. No need to run it.
draggin wagon04 is offline   Reply With Quote
Old 04-20-2005, 10:02 AM   #6
draggin wagon04
Member#: 39474
Integra GSR 4-door
I don't use it so make sure you do some more research on that HWG.
Old 04-20-2005, 01:28 PM   #7
randomthoughts
Member#: 71810
05 Evo 8
thanks for the help! is there any way to get full boost in 1 thru 3 cause those are the gears you use more often.. for drag,street, ect.......
hopefully my frontmount might help a bit in the cooling of the whole deal(the factory topmont sucks)
Old 04-20-2005, 02:06 PM   #8
crazymikie
Member#: 56321
2006 Honda El Camino
Green
HWG is if you are not hitting target boost in 3rd gear or so. You will never hit target boost in the lower gears since they go by so fast.
You can try the HWG map, however, I'd watch the boost gauge closely since you might experience spiking or overboosting if the wastegate duty cycle is too high.
Mike
crazymikie is offline   Reply With Quote
Old 04-20-2005, 02:14 PM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Just an FYI guys... remember what "boost" is... an excess of air not being used by the engine.
Just because it's not collecting in the lower gears, doesn't mean it's not being USED in the lower gears.
A motor is just a big air pump, the more that goes into and out of it, the more power you make.
So what you guys really should be doing is looking at MAF values, since that is a much more realistic indicator of power.
I.E. My car only makes about 15 PSI at the end of 1st gear, but makes 360 WHP in the process....
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
accessport problems. lordzappo Engine Management & Tuning 33 07-20-2005 06:05 PM
Help: AccessPort Problem Happy_Days Engine Management & Tuning 6 05-22-2005 12:33 AM
Accessport Problem kbarb03 South East Region Forum 3 03-03-2005 02:07 AM
Accessport Problems!! PLEASE READ!! speedypete Forester Forum 11 08-19-2004 02:23 PM
Accessport problems skieman Engine Management & Tuning 57 06-22-2004 01:46 PM
