Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-04-2005, 11:18 PM   #1
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
Default arggg! help its my first day...
i attempted to install an egt and a a/f ratio gage today, started up and check engine light is on, cruise light is blinking... dont know what i did wrong! gages do seem to work, no indicatons. is it possible that this could be the wrong wire off of the o2 sensor? any ideas at all? also, where did anyone who did this splice in their power/illum/ground wires at, could it just be a bad ground?
cliffhanger is offline   Reply With Quote
Old 04-05-2005, 07:47 PM   #2
mjalex007
Member#: 66022
2005 Baja Turbo
I have no idea what the problem might be, but I would at least try resetting the ECU (disconnect the battery).
mjalex007 is offline   Reply With Quote
Old 04-06-2005, 01:24 PM   #3
cliffhanger
Member#: 80446
2005 5spd Baja-T
i tried that and it didnt help...looks like ill be taking this one to a professional
Old 04-06-2005, 05:11 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
Ide start by undoing what you did. WHere did you tap in for the probe for your EGT and A/F guage? Did you already have bung in place for teh probes? Maybe you accidently left a sensor or so unplugged?
Hawk296 is offline   Reply With Quote
Old 04-06-2005, 09:19 PM   #5
cliffhanger
Member#: 80446
2005 5spd Baja-T
well, i undid what i did... talked with sam at xcceleration (real helpful guy! ) and he pretty much advised me against 'piggybacking' onto the stock o2 sensor b/c it always creates problems... i found that two of the wires on the plug for the egt were actually put in backwards! so i fixed the egt gauge and it works fine, and i will wait until i can order an a/f gage that comes with its own o2 sensor before i put that gage in i guess thx for the suggestions guys! btw, anyone know what a "max safe spec" for egt might be? thx...
Old 04-08-2005, 09:23 AM   #6
Hawk296
Member#: 14555
1995 Impreza L
Baja
Yeah I was kinda wondering if you had just spliced into the 02 or if you had a seperate one. EGT temp depends on where you are measuring it from. Are you using the factory EGT probe location in the uppipe or somewhere else?
Old 04-09-2005, 09:41 AM   #7
cliffhanger
Member#: 80446
2005 5spd Baja-T
i put the egt in the outlet of the header right before the uppipe--dont kjnow if this is a good place, but it seemed the most likely to get the most accurate readings
my first day with my new car home... AWWW (yeah it didn't start) Keith Off-Topic 107 03-18-2005 10:03 AM
My first day at my new job. Fish Off-Topic 34 11-29-2004 11:13 PM
its my b-day! dlowman South East Region Forum 11 08-02-2004 10:37 PM
Sighting lol, hey its my first one ;) Tim Quinn Vancouver Impreza Club Forum -- VIC 5 03-03-2004 09:50 PM
Its my last day of work!!! JewPac42 Off-Topic 0 08-08-2003 12:16 PM
