Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 06-06-2005, 02:59 PM   #1
deluxsti
Member#: 84313
04 Aspen STi
Default a/f learning and maf scaling
i just installed my perrin fmic and perrin big maf system.
and i got the a/f correction down to .78 at idle, but when im driving it climbs to 14.84 (i assume that is maxed out) then falls to around 7 or so when i go wot in the higher rpm's which is once it is out of closed loop. does this mean that i need to adjust the maf calibration more?? i have read that a af correction will bounce around alot when the maf is too low, but how do you know when you have gone too far in increasing the maf scaling?
i am using cobb street tuner
deluxsti is offline   Reply With Quote
Old 06-06-2005, 03:46 PM   #2
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
AF correction will bounce around when you accelerating and decelerating. Try to keep it at a constant load and a constant RPM when tuning the MAF. If your going uphill and then downhill, readings will be off.
darksands is offline   Reply With Quote
Old 06-06-2005, 04:22 PM   #3
x99percent
Member#: 27108
2004 STi
2004 A4
I have no experience with the ST software, but here's my guess, based on BigMAF experience with the UTEC:
Use the scaling to get things close (small A/F corrections) while at a cruise, and then make adjustments to the fuel map to make things proper at idle.
x99percent is offline   Reply With Quote
Turbo Swap and MAF Scaling scramjett Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-01-2010 10:42 AM
Maf scaling - need to be done with stock intake and injectors? Shadoxity Open Source Reflashes 10 05-03-2009 07:35 PM
Knocking on throttle down and lift after MAF scaling Fongers Open Source Reflashes 2 01-04-2009 06:17 PM
maf scaling and ecu definitions rebizap Commercial ECU Reflashes 2 10-31-2007 03:31 AM
Injector and MAF Scaling xolosis UTEC 3 10-07-2006 05:06 AM
