Old 04-05-2005, 02:25 PM   #1
fzturbo
Member#: 43482
2004 JDM 2 litre STI
Default What to expect from this setting
Soon i'm getting for my 2005 STI the next things:
-APS SR55 Turbo
-Blitz FMIC
-Walbro Fuel Pump
-Complete samco hoses kit
-CAI INJEN
-AP Fuel Rails
-RC 650cc Inyectors
-Devil Turbo Back Exhaust
-Custom Up-Pipe
-Cluth Master (for holding 400HP)
-Exhaust manifold?????????? (should I??)
Also i would be tuning with an AEM Wide band O2 Sensor and EGT. Thinking of boost up 25 PSI.
How much HP to expect from this set up.
Also, how mucho HP does the stock STI tranny can hold, and also the engine?????
Opinions and posible changes on the products would be usefull.
Thanks in advise
fzturbo is offline   Reply With Quote
Old 04-05-2005, 03:13 PM   #2
wrex03
Member#: 29963
04 sti
-APS SR55 Turbo
-Blitz FMIC
-Walbro Fuel Pump
-CAI INJEN
-AP Fuel Rails
-RC 650cc Inyectors
-Custom Up-Pipe
Thanks in advise
What EM are you getting, or do you already have one that is not listed above?
Might also want to go with larger injectors.
wrex03 is offline   Reply With Quote
Old 06-04-2005, 02:03 PM   #3
fzturbo
Member#: 43482
Nop, i dont have any EM. Wich one would be the best???
i've read that reflashes are for stock cars, will it be usefull on a modded STI???
Old 06-04-2005, 02:16 PM   #4
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Reflahses will be REQUIRED for your setup. Reflashes are good for stock cars, but as soon as you start playing with injectors and fuel rails, you MUST have good EM.
Have you considered replacing the stock MAP sensor, IIRC its only good to 18psi.
mcowger is offline   Reply With Quote
Old 06-04-2005, 02:49 PM   #5
fzturbo
Member#: 43482
I was planning to install a fuel cut defender to the stock Map. Does the fuelling compensation is by MAF signal, or i'm wrong???
Old 06-04-2005, 04:28 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
...Have you considered replacing the stock MAP sensor, IIRC its only good to 18psi.
Who says? I mean, it might not be good upto 25psi, but mine(on my wrx) seems to work fine upto 23. Where did you get 18 from?
What kinda fuel are you planning on using? I dunno how good your luck would be with running 25psi on an sti with pump gas, course ya never know I guess. Ya might wanna get a different turbo. Something like a fp green or a deadbolt superzilla can probably be gotten for less and might just help ya get more power. I don't really see the point in changing the uppipe, exhaust manifolds, or fuel rails. With the intake, ya might wanna look into one with a larger maf piping then stock. Something like the perrin big maf or the aps 70mm intake..... The stock tranny(other then the clutch) is good for a lot more power then you will probably ever run. Course I've never run that much power, or that much boost, so take this all with a grain of salt.
peace
How much power can I expect from this set-up? DegNY Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-05-2009 10:07 PM
what to expect from switching to smaller diameter wheels? blackie Tire & Wheel 12 01-15-2005 03:52 PM
What to expect from (TXS) catless turboback? Brian Broz Newbies & FAQs 1 10-09-2002 10:23 PM
What kind of power to expect from this setup? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-19-2002 12:51 PM
What to expect from RS? HubCap General Forum Archive 4 07-20-2000 01:18 AM
