Old 04-05-2005, 06:35 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default Has anyone tried the PerfectPower ECU yet?
I did a search and only came up with 3 results, so has anyone tried this yet? I'm looking for something to replace my S-AFC II since it really doesn't seem to do much for the MAP based Subaru (yes, color me wrong)
BrysImpreza is offline   Reply With Quote
Old 04-05-2005, 07:46 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
there are some posts on www.rallitek.net about this. They have had some decent success with it.
Jared
gtwagon941 is offline   Reply With Quote
Old 04-05-2005, 09:50 PM   #3
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
here is what the rallitek thread says:
Hey guys, we installed another PerfectPower today. This time is was a '00 RS that was basically stock. (Ganzflow intake box extension/axleback)
The car was running so rich (10.5:1 at the top end), if it ran any richer it wouldn't run! That tells me the mods done didn't flow any more air.
We installed a PerfectPower piggyback ecu and had the overfueling problem handled in about 2 hours. (Install / Tuning)
Those results are very different than the '04 RS we did a week or so ago. The '04 car had full bolt ons (Injen CAI/Borla Header/High flow cat/Full Catback) and was running very lean (14.2:1). Same test equipment installed in the same place(rear O2 sensor bung). So I am sure the results are accurate.
I need to continue installing these PerfectPower ECUs in different years/models on stock and modded cars so we know if the fueling differences come from the mods or if Subaru runs an '04 leaner than a '00.
With just bolt on mods and PerfectPower, RalliTEK made 126whp on a Mustang Dyno. Mustang dynos are notorious for reading low. The car has 48K miles, lightened pulley/flywheel, AEM intake, and TechWorks header/cat delete, and 5Zigen Catback. Here is the dyno sheet.
__________________
allsubaru83 is offline   Reply With Quote
Old 04-05-2005, 10:35 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
If only it controlled the revlimit...... Seems like a decent unit other than that one major function.
Jay Storm
Old 04-05-2005, 11:56 PM   #5
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
yeah the reviews on rallitek seem to be good, even though they are done by the shop which mught be a little one sided justt to push the item but form what i have read it is a decent mod...
Old 04-06-2005, 08:11 AM   #6
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I'm just curious if you have to use premium gas like most chip require. The whole reason I got rid of my FXT and bought the TS was to save on gas.
Old 04-06-2005, 08:58 AM   #7
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
storm,
is there anything available that will let me bump my rev limiter?
i have some spicy cams and would love to tap that upper end...
staticfritz is offline   Reply With Quote
Old 05-29-2005, 03:01 PM   #8
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Rev limit will require a standalone or a reflash. I have only heard of one re-flash. (Yoshi in Canada.)
PerfectPower has lots of features, but higher rev limit is not one of them.
Since it is a fully laptop programable engine management system(we use our PPs on WRX/STi/LGT...) You can set it up for 87, then switch maps and use 92. Or, go from 87 to race fuel or......
I can pre-program that kind of thing for you if you prefer.
Aside from the fuel and Timing control, RalliTEK PerfectPower features:
-Launch Control
-Boost Control
-Conditional Warning/Shift Light
-Has Air/Fuel Ratio Meter (NB)
-Simple to Use Windows Software
-Live data with Data Logger
-Overheat Protection
-Over Boost Protection
This is the full deal. The downside is it must be wired in. That is why we can offer is for such a great price. Wiring is fairly simple. I include wiring diagrams, instructions, and I am available by phone, IM, Email..... If you have any install trouble.
Check out the latest at www.rallitek.net in our RalliTEK PerfectPower Forums.
-Sean S.
RalliTEK Subaru
www.RalliTEK.com / www.rallitek.net
Rallitek.com is offline   Reply With Quote
Old 05-29-2005, 04:54 PM   #9
shoeler25
Member#: 52202
2001 2.5RS
Would this system help with lame CELs from bolt ons? More specifically the P0402(did I get the number right?) the cat inefficient one. Thanks.
shoeler25 is offline   Reply With Quote
Old 05-30-2005, 01:15 AM   #10
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
PerfectPower can't help with the Cat P0420 code. It can help other codes, like running lean, or rich....
More info @ www.rallitek.net
-Sean S.
Old 05-30-2005, 10:45 AM   #11
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
You guys plan on having other shops install this device, such as Rallispec, etc? I'd be interested in trying something like this on an older modelled subaru. It's not a plug and plag device anyways so.....
Kevin Thomas is offline   Reply With Quote
Old 05-30-2005, 10:55 AM   #12
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Nope, but piggybacking a 2.2ohm resistor in the place of the O2 sensor plug will
Old 05-30-2005, 01:19 PM   #13
shoeler25
Member#: 52202
2001 2.5RS
2.2k ohm I believe. Im aware of the fixes for that code, waiting to have time to try the mechanical fix actually. Just curious if the system would help.
Old 05-31-2005, 02:07 PM   #14
ricochet
Driving Sports TV Staff
Member#: 15542
1991 Legacy Sedan
We're running the Rallitek PerfectPower Piggyback on the 2005 Subiesport Zero-to-Hero 2.5RS Project car--Rallitek is one of the project sponsors. It is my understanding that they will be making the maps we build off the ZtH car available to their customers.
We just finished up a tuning session with bolt-ons (header, intake, exhaust) and are adding COBB Spicy Cams next week. Full results should appear in the October 05 issue of Subiesport Magazine...right now we're still sifting through the data from the frist dyno runs and wont get the second in (with cams) for a few more weeks.
Ryan Douthit
Subiesport Magazine
http://www.subiesport.com
ricochet is offline   Reply With Quote
Old 05-31-2005, 02:18 PM   #15
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
I think short of a reflash, this is quite a good deal - I haven't used it but this is almost like an eManage. My Link doesn't have all the features I need for a good stock tune and reflashes from i-Speed is still quite a ways away. Didn't really feel like dropping my Link and swing for a PP and redo all the wiring
kgb is offline   Reply With Quote
Old 05-31-2005, 02:18 PM   #16
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Very cool, I'm going to replace my Apex'i S-AFC 2 very soon with a Perfect Power. I'm curious to see what my car will do after adding a few more parts then the P.P.
Next in Line: 4 into 1 headers, 2.25" custom catback into an 05 WRX muffler, Mr. Josh Pulley then comes the perfect power.
Currently: K&N Panel filter, Homemade 3" intake piping, S-AFC 2 (useless on an MAF'ed car) Random Tech Hi-flow into 2.25" catback with 03 WRX muffler.
If I can make 200 at the crank, I'll be happy.
Old 05-31-2005, 02:23 PM   #17
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Good luck on your quest for 200 - it's hard man, even at the crank. Technology is not on our side when it comes to the EJs
Old 05-31-2005, 02:55 PM   #18
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Are you sure it is worthless on a MAF car. I think it works on the MAF cars but is useless on the MAP cars.
.02
Jared
Old 05-31-2005, 03:09 PM   #19
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
.02
Jared
Yup, thats what I meant, I've had to explain it to newbies so many times my head is starting to spin.
It sucks we can't make 200 easily on a 2.5 liter, Honda can make a 2.0 make 245HP in the S2000 and it gets better gas mileage!
Ah well, any gains without going turbo or mesing with internals are good ones. Maybe there will be some hope with the new 2.5 coming out next year, direct injection seems to boost the power to about 175HP... better then nothing.
Old 05-31-2005, 03:11 PM   #20
ricochet
Member#: 15542
1991 Legacy Sedan
A very peaky 200hp, with little relative torque (I used to have a '98 Integra 1.8L GSR that had a fair bit of mods on it.)
Has anyone tried the Ipod/Iphone XM SkyDock in their car yet? BlackpearlSTI Car Audio, Video & Security 1 12-28-2009 07:38 AM
Has anyone tried the TiC Klunk Killer yet? Greg B Transmission (AT/MT) & Driveline 14 10-04-2005 01:28 AM
Has anyone tried the MAP ECU??? styng88 Outback Forum 3 10-19-2004 11:04 PM
Has anyone got the subaru ecu reflash yet? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-16-2002 02:55 PM
Has anyone tried the Link ECU on the WRX? CobraKLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-13-2002 10:09 AM
