Old 04-05-2005, 07:22 PM   #1
TexSurfer
Member#: 76072
Default Simple question....
....do i have to have a wideband o2 to get a proper tune with the UTEC? I know I need the wideband just want to know if I need it right now. Thanks!
TexSurfer is offline   Reply With Quote
Old 04-05-2005, 07:41 PM   #2
crestgel
Member#: 76607
bump i want to know too
crestgel is offline   Reply With Quote
Old 04-05-2005, 09:13 PM   #3
Skeete
Member#: 52569
2004 STi
if you are tuning it yourself then i think it would be very helpful, so that you'll be sure your a/f ratio is good...
Skeete is offline   Reply With Quote
Old 04-06-2005, 09:14 AM   #4
TexSurfer
Member#: 76072
i know i need it eventually, but i can't afford to do both the utec and a wideband right now. so i was thinking if i just used the preset maps for the utec i would be ok a/f wise. is that true?
Old 04-06-2005, 10:33 AM   #5
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Every car will be slightly different and unless you have the exact mods listed for the map and nothing else, there's no way to know for sure that your AFR's are on target. If you have an EGT gauge and plan on running the off-the-shelf maps, then that should be sufficient to monitor how the car is handleing the map. Maybe you can find someone who will lend you their WB for a couple pulls to verify AFR's. I have access to just that and it's saved me buying the LM-1. Looks like the LC-1 is going to be the WB of choice for tuning now though so I might be buying one sooner than later. Check out the thread here
phantomsr is offline   Reply With Quote
Old 04-06-2005, 11:12 AM   #6
TexSurfer
Member#: 76072
thanks for the info. that's pretty much what i needed to know.
Simple question, Simple answer Impreza541 Transmission (AT/MT) & Driveline 6 01-01-2009 08:08 PM
Simple question, simple answer needed: jtdbsr Off-Topic 32 04-06-2005 05:00 PM
Three Simple Questions. DoomEquation Normally Aspirated Powertrain 9 05-30-2001 11:56 AM
Simple question au112 Newbies & FAQs 5 03-30-2001 12:09 AM
Simple question.. A-Pillar burr101 General Forum Archive 4 07-07-2000 11:30 AM
