Old 04-05-2005, 08:56 PM   #1
zacek
Member#: 19467
02 WRX
WR Blue
Default Help! Quick question on running rich...
Ok, maybe not so quick....
ok, I got the APS SR-55 and the Perrin Moded Injectors Installed. I am planing on having the STi reflashed by Shiv in the next 2 or 3 weeks because I am awaiting for other parts such as Turbo-Inlet hose, and Perrin's new Boost Solenoid.
At 1st. the car had a hard time starting but it did. However it won't drive properly, and it stalls just as expected.
I switch the 65mm APS intake with my old 70mm APS intake to help out lean the already super rich mixture. It did help but it still feels shaky, I can however drive around the block now. I am not sure how rich is running but the Autometer A/F gauge is out of its range. While driving it the CE light flashes a few times and then it goes away, a few moments later the sequence repeats itself and after a few times the CE light just remains on. This leads me to believe that the ratio is zig-zaging in the threshold between an aceptable range and the range for the CE light. All other indicators such as EGT, BOOST look good. I am staying in the vacuum side for the most part.
Question... would it be safe to drive the 400+ miles over to Shiv or I am just better off sending the ECU over to him (like someone else suggested) and let him flash a base map with the scaled injectors and then do the dynotuning at another time?
Another quickie, should I have the car tuned with the 65 or the 70mm intake? It seems pegging the stock MAF is pretty common with big turbos but I won't be runing more than 18-19 psi since I only have 91 octane to play with.
zacek is offline   Reply With Quote
quick question on running higher cc injectors mystilexzero Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-17-2008 06:31 PM
quick question on similarities on harnesses simprezl25 Subaru Conversions 1 11-29-2005 10:42 AM
!!! need help quick. Can you run a 215/45/17 tire on a 17x8 wheel? sepulcherx Tire & Wheel 5 09-09-2005 11:39 PM
Hypothetical question on running rich Retro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-18-2005 03:59 PM
Question on running rich Rubik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-25-2001 05:45 AM
