Old 04-17-2001, 01:45 AM   #1
D
Member#: 3161
Question At the limit?
Hi.
Tax season is over and while awaiting my refund I've been salivating over the numerous things that I can do ranging from suspension work to rims to engine mods and possibly driving school.
Before I do make a decision, I have a question about driving at the limit, what it feels like, and how suspension affects it. It basically goes like this... when driving at the limit, is it a much more sudden onset when you have better suspension then worse suspension? An example to clear it up would be driving in as tight a circle as you can as fast as you can. In stock suspension, the body roll and tire noise will probably be evident almost immediately and gradually gets worse until the car breaks completely lose. In a better suspension setup, will the car be nice and smooth and then suddenly lose it? Meaning because you have a nice tight chasis and sway bars and strut bars and coilovers all over, you can get closer to the limit, but won't know how close you're straddling it until it's dangling between a fine edge. Then it's either on one side or the other with no real warning of how close you are?
Background behind this question is I'd like to get new suspension eventually but am also looking at classes. Would it be better to learn on a more stock car which gives you signs much earlier? Or does better suspension also give you as much warning, but due to your car's better handling gives you a "higher" limit to reach for?
Thanks!
D
D is offline   Reply With Quote
Old 04-17-2001, 12:23 PM   #2
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
Post
I don't know a specific answer to this, but FWIW, I think you'd be better off going to classes with the suspension that you plan on using all the time. If you will have a nice suspension set-up, learn on it...if you use the stock set-up, then learn on that.
thebusiness999 is offline   Reply With Quote
Old 04-17-2001, 02:51 PM   #3
OldWRXr
Member#: 4650
Exclamation
Yeah, I'd opt for the driving school. You'll be able to learn about "limits" in a classroom setting before going to the track. There are many different ways suspension mods work, but for the most part a stiffer suspension works to keep the tires planted more firmly on the ground and reduces body roll.
OldWRXr is offline   Reply With Quote
Travelling at 90 miles per hour . . . over the limit. Howl Off-Topic 65 08-13-2009 08:40 PM
Tuning at the sensor limits (long discussion) sponaugle Engine Management & Tuning 37 06-15-2007 01:00 PM
PR: SG Racing Finds the Limit at Rim ProRally johnfelstead Motorsports 16 05-14-2004 01:46 PM
