Old 04-05-2005, 10:32 PM   #1
REXLR8
Member#: 70937
2006 VW GTi
RED
Default utec and boost #'s??
whats the translation here? i tried to play around with the boost settings, and it reads 300 at the base stage 2 map? 300 what? and how much does 1psi equal?
REXLR8 is offline   Reply With Quote
Old 04-05-2005, 10:47 PM   #2
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
The boost numbers are unitless with no direct correlation to psi. Play with the map until you get the boost you want.
Blennophobic is offline   Reply With Quote
Old 04-05-2005, 10:48 PM   #3
REXLR8
Member#: 70937
2006 VW GTi
RED
so its just a random number? ok cool, ill just go by 50's until i get the boost how i like it, thanks
Old 04-06-2005, 12:16 AM   #4
Gethin
Member#: 2998
It's not random. It's a target number to reach to get the desired PSI.
Target PSI changes from stage to stage and needs to be properly tuned for RPM load points.
Playing around with the UTEC will result in a destroyed engine.
For your engines sake read the UTEC manual!
http://www.turboxs.com/_images/UTEC/...nual%204.2.pdf
And mick's tuning guide
http://www.pdxtuning.com/utec_tune_g...12_02_2004.pdf
Make sure you are using 4.2c firmware with those new TurboXS maps from their website, and also the correct constant parameters file for your stage.
Good luck.
Gethin is offline   Reply With Quote
Old 04-06-2005, 09:01 AM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
I would use a smaller incremental number then 50. Try 10, unless you're 4-5psi under your target.
AaronWRX is offline   Reply With Quote
Old 04-07-2005, 03:19 PM   #6
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
yah it is just a random number and doesnt correspond to any boost level... but I might try going up by 20-30 rather than 50s... 50 can be a big jump.
dosage0 is offline   Reply With Quote
Question about utec and boost controler Stiturbos Engine Management & Tuning 11 02-24-2005 03:55 AM
HP #'s with UTEC and boltons BOOSTEDTREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-02-2005 04:18 PM
UTEC and boost issues dirtyhartland Engine Management & Tuning 9 11-25-2004 01:49 PM
Cobb Stage 2 Dyno #'s and Boost Question Jard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 10-31-2004 11:52 PM
Help on UTEC and Boost Controller Azjon Newbies & FAQs 2 02-03-2004 02:04 PM
