Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-06-2005, 03:36 PM   #1
02TREX
Member#: 9398
2004 WRX STI
[email protected] Cobb AP Stage 2
Default Front Differential Drain Plug Torx Bit Size?
I have an 03 Baja NA with an automatic transmission. I am attempting to change the fluid in the front differential and I see that it requires a torx bit to remove the drain plug.
Does anyone know what size torx bit I need to remove the drain plug? Is it the same as some of the AT WRXs (T70)?
Thanks in advance.
02TREX is offline   Reply With Quote
Old 04-08-2005, 10:06 PM   #2
mbaksic
Member#: 78280
2003 Baja Classic
Regatta Red/Silver
I just changed my axle fluid today, front and rear. The front must be a T70. I had a T 60, and it fit very loose. It did work, but I plan on getting a 70 next week from the tool guys to see if that is the correct one. Mike
mbaksic is offline   Reply With Quote
Old 04-11-2005, 06:58 AM   #3
02TREX
Member#: 9398
2004 WRX STI
Thanks for the reply. I'll see if I can find a cheap T60 before I shell out for the T70.
Let me know if the 70 fits.
Front diff drain plug question? Rally Monkey Service & Maintenance 20 05-21-2007 11:10 AM
front diff drain plug ufa turtle Transmission (AT/MT) & Driveline 4 04-28-2005 11:00 AM
95 Impreza: Front Differential Drain Plug/Washer question kevinsUBARU Service & Maintenance 6 12-09-2004 03:46 PM
manual transmission drain plug sealing washer size? STi-Nismo Dood Southern California Impreza Club Forum -- SCIC 1 05-02-2003 11:43 PM
MY02 rear differential drain plugs bigger than half inch drive ratchet? bigpaulo Service & Maintenance 8 11-20-2002 04:09 PM
