Old 04-06-2005, 03:50 PM   #1
GetSideways
Member#: 44665
03 wrx sedan
platinum
Default CEL's that go away???
Is it possible for the car to throw a CEL and then after a few hundred miles turn the CEL light off on its own (without me pulling the battery?) If so why would it do this? Has this happened to anyone else?
I've got an 03 with accessport stg 2 (93 oct.) ; headers; blitz sbc (16-17psi); full TBE; BOV.......
GetSideways is offline   Reply With Quote
Old 04-06-2005, 04:06 PM   #2
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
If you have the AP, why don't you pull the code?
phantomsr is offline   Reply With Quote
Old 04-06-2005, 04:13 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I agree, you should pull the code.
And the answer is yes. When a problem is detected, the ECU sets a code and turns on the CEL. As long as the problem continues to be seen by the ECU the light will stay on. However if it is no longer detected over several consecutive drive cycles, the light will go off although the code will remain stored in memory. The light going off does not mean that all is well and you can go happily on your way, it just means that the problem or condition is gone at least for the time being. It can always come back.
Old 04-06-2005, 06:18 PM   #4
GetSideways
Member#: 44665
03 wrx sedan
platinum
i would pull the code but i dont have the port, just the old access ecu...
Old 04-06-2005, 07:44 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Either go to Autozone and they will read it for free, or ask for help in your local forum. Lots of people have scanners.
What CEL's don't go away after a ECU reset? Aaron'z 2.5RS Service & Maintenance 2 08-17-2007 12:26 PM
For all that havent seen 2002wrx-2004wrsti? 56k go away!! D-I-Z-Z-L-E Member's Car Gallery 55 04-08-2004 01:57 AM
CEL's that don't go away <help> T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-06-2004 09:09 AM
Do CEL's just go away?? Mine Did Ed_RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-19-2001 11:21 AM
