Old 07-24-2001, 04:49 PM   #1
JoelR
Member#: 713
Default Re-Building a bulletproof '98 DOHC
I'm in the middle of figuring out whether my engine ('98 2.5 RS with Minnam Stage I turbo) which lost oil pressure recently will be covered by my powertrain warranty or not. If it is, great, I'll let Subaru rebuild the damn thing back up to std. specs. If not, I want to rebuild it to better-then-new specs so I can avoid such troubles in the future.
1. Crank: What should I do to the bottom end to bullet-proof the crank, its bearings, oil supply to bearings (esp. cyl. 3), etc?
2. Oil Pump: Is there a high-flow oil pump that's worth using as a replacement? I've heard high-flow is better than high-pressure.
3. Pistons: I love the torque that the 9.7:1 compression + boost gives me so I'm hesitant to drop the compression much. However, stronger pistons might be a nice improvement. I've also heard the '98 DOHC has short-skirted pistons, which is bad (on an engine, not a girl).
4. Rods: Worth replacing? I've heard bad things about the way that our rod ends bolt on.
5. Block: Should it be required to swap the actual block, what about swapping to a '99+ Phase II block with the crank's thrust bearing relocated? I've heard people call a 2.5L DOHC phase II the "magic engine". I understand that my 4 bolt transmission would still mate to this engine, just with some unused lugs on the block.
Any other ideas?
Thanks!!
Joel
JoelR is offline   Reply With Quote
Old 07-24-2001, 04:52 PM   #2
TR
Member#: 28
1997 M3 Sedan
better than stock head gaskets would be nice too.
TR is offline   Reply With Quote
Finally building my "new" engine - DOHC heads on Phase II block Patrick Olsen Normally Aspirated Powertrain 113 04-04-2013 10:06 PM
'04 STI Block , '98 DOHC Heads ??? SOHCEJ25 Built Motor Discussion 5 11-24-2008 08:15 PM
WTB: '98 DOHC EJ25 Wiring harness rvanbran Private 'Wanted' Classifieds 0 12-11-2003 09:04 PM
Definitive Post on ECU re-building Fuel/Ignition Maps is2scooby Engine Management & Tuning 8 11-07-2002 05:54 PM
Difference between '98 DOHC and '99 and up SOHC danc Normally Aspirated Powertrain 1 08-04-2001 02:15 PM
Message Board Statistics All times are GMT -4. The time now is 03:01 PM.
