Old 04-07-2005, 11:06 AM   #1
UK_SUB
Member#: 84446
2003 WRX Wagon
Subaru Stars Cobb stage 2??
Hi
I have an 03 WRX Wagon with 30,000 miles a TurboXS turbo back and a waste gate solenoid by-pass, boost arrangement of some kind, it's currently running about 1 bar max boost (which I think is stock max boost??).
I've done a bit of research on here, and have seen lots of good things said about the Cobb AP stage 2. I am trying to decide weather to add an up pipe to my shopping list, this is my first turbo awd car, and I really hate that crappy 'nothing happens till 4000rpm’ turbo lag thing.
My question is: would the up pipe reduce the lag significantly?? Does the AP 2 reduce lag/improve low end performance to the point where an up pipe would be less of an issue? Also has anyone had problems with the pre-turbo cat failing and putting debris through the turbo? Should this be a consideration when upgrading a car of this age / mileage??
Anyone got any ideas? AP 2? AP 2 and up-pipe? Up-pipe before or the after AP 2?
Any advice would be much appreciated
Thanks in advance
Jon
UK_SUB is offline   Reply With Quote
Old 04-07-2005, 03:09 PM   #2
subenerd
Member#: 72630
2004 STi
Yes, you will spool much faster without that catalytic converter in there. Its main function is to reduce emissions on cold starts. I gutted my cat when I installed my TXS turboback and it spools much faster (better acceleration)
AP stage 2 doesnt include the uppipe, but you will benifet from the quicker spool
yes, PM Davenow
Do the uppipe AND AP stage 2 at the same time-you will be happy
subenerd is offline   Reply With Quote
Old 04-07-2005, 08:32 PM   #3
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
my friend had a cobb stage 2 with an uppipe.. i have a cobb stage 2 without one. we never pulled on eachother. our cars were dead even. i have an up waiting to be installed. if you can get both the ap and the up pipe install together, do it.
WRXdriver04 is offline   Reply With Quote
cobb stage 2 vs. prodrive stage 2 oxtox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2005 08:59 AM
Cobb stage 2 (w mods) VS. Cobb stage 2 (w mods) Happy_Days Proven Power Bragging 7 11-28-2004 04:25 AM
Those who upgraded from Cobb stage 2 to stage 2.5 WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-29-2004 04:56 PM
Turbo XS Stage 2 or Cobb Stage 2???? NBWRX04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2004 07:32 PM
TXS stage 2 Unichip vs Cobb Stage 2 Access ECU ezatnova Engine Management & Tuning 8 02-09-2004 08:54 AM
