Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 04-07-2005, 02:42 PM   #1
trex1200r
Member#: 56019
2004 Forester XT
Unhappy How to test for boost leak?
Only getting 9psi on cobb stage 2. Cobb told me to check for vacuum leaks/intercooler leaks etc. Anyone know of an easy way to check for leaks?
TREX
trex1200r is offline   Reply With Quote
Old 04-07-2005, 03:22 PM   #2
richy_21
Member#: 58670
2005 got muuuuu?
do a leak test...you can buy the parts need @ home depot and then you need a air compressor. pm me...and ill tell you what you need. Where are you located? Im actually gonna do mine hopefully this week
richy_21 is offline   Reply With Quote
Old 04-11-2005, 03:36 PM   #3
trex1200r
Member#: 56019
2004 Forester XT
Well, I am not sure why it worked...but adjusted the waste gate arm tighter 1.5 turns to increase the preload. Now holds 11-12 psi in 1st and second. Haven't tried a high speed run yet. But it is like completely new car.
Old 04-11-2005, 04:04 PM   #4
subieworx
Member#: 47769
It should be building more than that.
subieworx is offline   Reply With Quote
Old 04-11-2005, 10:05 PM   #5
deluxsti
Member#: 84313
04 Aspen STi
i have stage 2 and am running 18.3+ boost.
deluxsti is offline   Reply With Quote
Old 04-11-2005, 10:36 PM   #6
CreoWRX
Member#: 19024
2014 Audi S6 + APR
Glacier White
In 3rd or 4th (not sure which gear they used), you should see around 13.5psi tapering to 10psi... On your FXT, of course.
http://cobbtuning.com/forester/images/ap-fxt-stage2.gif
-Mike-
CreoWRX is offline   Reply With Quote
Old 04-11-2005, 11:41 PM   #7
Evil STI
Member#: 36792
2014 Camaro 1LE
gold chains & meatballs
Are you running a BOV?
Evil STI is offline   Reply With Quote
Old 04-12-2005, 01:51 PM   #8
trex1200r
Member#: 56019
2004 Forester XT
I am not running a BOV. Cobb told me I would not see target boost unless wot in 3rd and 4th gear. Haven't had a chance to test it out yet...too much traffic. I can say that 11-12 psi in 1st and second gear is a huge improvement to what I was getting. Before adjusted the waste gate tension, was only holding 9 psi in any gear.
TREX
Old 04-12-2005, 04:42 PM   #9
Zumble
Member#: 34860
2005 Forester CGM
That's really bad! Now that it's warmer I see 14.5-15psi with fxt stage 2.
TREX
Zumble is offline   Reply With Quote
Old 04-12-2005, 06:30 PM   #10
trex1200r
Member#: 56019
2004 Forester XT
Hey Zumble, do you have a manual or the auto? Not sure if it makes a difference, but it has always sounded like the manual runs rings around the auto, more than drive train losses would justify. Just wonder if autos have a more moderate tune/boost tune that the manual. As you might guess, mine is the auto
Also, do you get 14-15 in 1st and 2nd? Must be fun!
TREX
Old 04-13-2005, 04:46 AM   #11
Zumble
Member#: 34860
2005 Forester CGM
I have a manual. No, I don't see full boost in 1st and 2nd. I think those are limited to about 10psi in 1st and 12 psi in 2nd. The manual is as fast as it is because of the gearing. The 4 speed auto probably has wider gearing than the close ratio 5 speed. The 5-speed FXT revs up really fast. I hit 16psi once when it was about 30 degrees outside. That was in 5th gear chasing a vette. I think I gave him a bit of a scare. I knew I hit 16 because my overboost warning is set at 16. I heard the beep and the light flash for a split second. I recalled the peak and it was at 16. =)
TREX
how to log for boost leak 06-wrx-tr Open Source Reflashes 1 07-06-2009 07:45 PM
Bad Idea? testing for boost leak The Satch Newbies & FAQs 7 04-23-2009 07:10 PM
how to test for boost leaks? subylove8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-17-2007 05:21 PM
Tell me how to do a boost leak test? PLEASE!! ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-15-2006 01:00 AM
How to test for Up-pipe leak? aspenwhitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-26-2004 02:11 AM
