Old 04-07-2005, 03:34 PM   #1
sebtarta
Member#: 82883
2006 2.5i Wagon
'72 Nova Turns & Stops
Default STI Sway Bars - Do they fit?
Hi all, wondering if STI stock sway bars fit on a 2001 2.5 RS?? Are they any better than the stock RS sway bars?
sebtarta is offline   Reply With Quote
Old 04-07-2005, 03:35 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
No.....
There are many many aftermarket bars out there. Look at www.gruppe-s.com or some other vendors.
supermarkus is offline   Reply With Quote
Old 04-07-2005, 03:37 PM   #3
sebtarta
Member#: 82883
2006 2.5i Wagon
Originally Posted by supermarkus
No.....
I know they are many aftermarket sways, just wanted to know, because there is a sale on the front/rear sti sways for a good price.....just needed the info. Thank you for your help.
Old 04-07-2005, 03:40 PM   #4
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i dont think so.
here is some good ones.
http://www.rallitek.com/products.asp...&HB=Y&ACC=&SP=
http://boxer4racing.com/ (sorry they dont have individual links, just click rs then suspension then sway bars)
svek is offline   Reply With Quote
Old 04-07-2005, 05:50 PM   #5
Siper2
Member#: 1134
2007 BMW 328xi wagon
Lightbulb
Anything's better than the stock RS rear swaybar, which is 13mm. VERY tiny.
www.subaruwrxparts.com/gc8.html
Some of the better prices on bars. Brand new 18 or 20mm FHI (Subaru) swaybars fit directly, and are $80.
Cheaper, usually, if you buy used. The 20mm was stock on the '02 (and maybe other years) WRX sedan (not the wagons).
Otherwise, there's Whiteline, Cusco, Perrin.... lots of aftermarket options. If you go aftermarket, I'd say Cusco's the highest quality of the bunch, at least that I've seen.
The stock FRONT swaybar is 19mm, and very good on its own. Modify your suspension/tires/etc. first before messing with that one. Check www.northursalia.com for a great page or two on Swaybar tech and how the sizing affects your car. Each millimeter you go up, the effect is exponential, not merely additional. 18mm is typically best with a stock RS suspension. 20mm is best with lightly-modified or STi/equivalent strut/spring setups for road use. 22mm is best for coilovers and cars that see more track use.
Any larger than that and you're in to serious race diameter, much too much for a street car, in my opinion. Plus you'll absolutely need upgraded droplinks and mounting hardware, lest you snap your stock pieces into bits around some "spirited" corner in the middle of the night.
=S2=
Siper2 is offline   Reply With Quote
Old 04-07-2005, 07:12 PM   #6
sebtarta
Member#: 82883
2006 2.5i Wagon
Slper2, no words to say THANK YOU Amazing, that helped me a lot. In fact i learned a lot, which i like.
Thank you once again.
Old 04-07-2005, 09:46 PM   #7
Siper2
Member#: 1134
Thumbs up
Hey no sweat. For what it's worth, I have an STi Version 5/6 strut & spring combo on my car, and a Whiteline 18-22mm adjustable rear sway. Stock front sway.
I had the Whiteline set to 18mm before the suspension, and 20mm after (which was Oct. 2001 for installation). I've never put it on 22.
I'm probably going to swap to an FHI 20mm bar ASAP. Mostly because mine's pretty old and rusty, and the FHI ones fit better. Plus I never use the adjustability, so I feel almost like it's wasted on my car.
Brian, or North Ursalia, runs Ravensblade-Impreza *and* the Parts Counter at www.subaruwrxparts.com, which is Exeter Subaru in NH. No sales tax in NH, which is nice incentive to buy there, too. He's a parts guru, and knows every Subaru part ever made, inside-out and backwards. Ever need a part number (or PN), he's your guy.
There's a ton of sites that are of help. Just don't ignore www.scoobymods.com. It's where most of us still go to learn.
=S2=
ps - Me and my manners...... You're welcome!
2005 STI Springs and Sway Bar...Will they fit my 05 WRX Wagon? wrx05 Brakes, Steering & Suspension 5 05-05-2011 06:16 PM
Electronic detachable sway bar-do they exist for subarus? soulbazz Brakes, Steering & Suspension 2 10-27-2008 09:44 AM
STI rear seats.. do they fit into a wagon? 03boxer4 Interior & Exterior Modification 2 02-18-2007 10:32 AM
"tall" Perrin rear sway bar mounts on 06STI..do they fit? Mojambo Brakes, Steering & Suspension 0 02-15-2007 11:44 PM
