Mid Atlantic Impreza Club
Old 04-07-2005, 03:59 PM   #1
thorondor
Member#: 67304
2005 STI
CGM
Default Do any of our Mid-A vendors sell the Autometer Nexus gauges?
Cheaper than the Defi, and they do data logging and a few other cool things, I think this is what I am going with...
I would prefer to buy from a Mid-A vendor if possible in the spirit of helping out NASIOC(ers) in our local area.
thorondor is offline   Reply With Quote
Old 04-07-2005, 04:04 PM   #2
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
How much cheaper?
Jard is online now   Reply With Quote
Old 04-07-2005, 04:13 PM   #3
jmj1112
Member#: 57051
02 WRX
I think Dan at Mach V said he would be getting those in ......
And they are a lot cheaper than the Defi at least thats what Dan said!!!!!!
jmj1112 is offline   Reply With Quote
Old 04-07-2005, 04:14 PM   #4
thorondor
Member#: 67304
2005 STI
CGM
Default Not sure...
Cheaper seems to be the consensus, there is a post in interior/exterior where a guy had the control box/remote and Boost/EGT gauges installed at a dealership for $1k, he said the parts themselves were just under $700....
Old 04-07-2005, 04:15 PM   #5
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
-- Dave
AcquaCow is offline   Reply With Quote
Old 04-07-2005, 04:18 PM   #6
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I say "meh" unless they are really a lot chaper for just the parts. I can do the install myself.
I will say that I'm a DEFI fanboi.
Old 04-07-2005, 04:24 PM   #7
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Labor is also always free at install parties.
Old 04-07-2005, 04:33 PM   #8
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
And thank you for that
IMO the color changing trick with the autometers is a little too ricey. As for prices on Defi's..if you cant get em from MachV then...
http://www.gruppe-s.com/Defi/defimeter.htm
These DO have some cool features other than the color change thang.
D_Block is offline   Reply With Quote
Old 04-07-2005, 04:45 PM   #9
thorondor
Member#: 67304
2005 STI
CGM
So do the Autometer ones, I am not too concerned with the color change, I am more interested in the ability to do data logging to an SD memory card which you can then read on your computer.
That ability alone is worth it to me...
Are you sure you aren't just infected with the "JDM itch:???
Old 04-07-2005, 04:48 PM   #10
LotusDriftx
Member#: 48528
SAY WHAAAAAAAAAAAT!?!?
wow thats pretty nifty. I can't think of any reason I really need to save the data so I can view it on my computer, but its neat nontheless...
<-purchasing DEFI's this weekend
LotusDriftx is offline   Reply With Quote
Old 04-07-2005, 04:49 PM   #11
thorondor
Member#: 67304
2005 STI
CGM
Default Hmmm...
Well tuning is a pretty good reason... As the proud owner of an AccessPort I plan on getting some AccessTuner sweetness and tweaking things myself, being able to log your WOT runs is a pretty cool feature for road tuning methinks.
Don't get me wrong, the Defi gauges are the hotness.
Old 04-07-2005, 04:49 PM   #12
D_Block
Member#: 64127
on order
I meant that the AUTOMETERS do have some cool features. Not neccesarily JDM itch, just cheap parts itch. I got mine from Jard for 400
Old 04-07-2005, 04:51 PM   #13
thorondor
Member#: 67304
2005 STI
CGM
Sweet price! What gauges?
Old 04-07-2005, 04:51 PM   #14
D_Block
Member#: 64127
on order
UTEC does that, wont the street tuner? Not hating, they do seem pretty cool.
For which car? The one that runs?
Old 04-07-2005, 04:52 PM   #15
D_Block
Member#: 64127
on order
The defi link boost,cu,oilpressure,egt plus the pod cause Jard is a sweetheart.
Old 04-07-2005, 04:53 PM   #16
LotusDriftx
Member#: 48528
ya most people with all these gauges have some kind of tuning or datalogging capability already. Logging your EGT's by themselves isn't all that useful IMO. Now If it has a possible wideband integrated, and an rpm graph laid on top, THAT is useful.
Old 04-07-2005, 04:53 PM   #17
thorondor
Member#: 67304
2005 STI
CGM
Default Not sure...
Even if it does just plugging a memory stick into my car is a lot more convienent than driving around wiht a laptop hanging out of my OBD-II port!
*EDIT*
I should have known better than to post something inflamatory right before 5pm... Everyone has that surf the internet for the last hour of the day until the clock says I can go home thing going on.
Old 04-07-2005, 04:58 PM   #18
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
The AccessTUNER for the STi reads all the data you would need from the ECU. It however does not do all this for the regular WRX.
From Cobb's Site:
Dashboard
Get instant vital statistics while tuning using the StreetTUNER floating dashboard. Simply move the dashboard into an area most convenient for your use and continue to make adjustments to your map data. The Dashboard will show you critical data such as Load, RPM, Engine Coolant Temp, Knock, A/F, and more. All data is displayed in an easy to read digital format. StreetTUNER software
Datalogging
Capture and save critical engine parameter data. When in datalogging mode, the StreetTUNER software will capture the data you specify and store the information in a industry-standard .csv format file. This means you can easily import it into any standard Spreadsheet software to view, graph, and share with others.
Available Dashboard / Datalogging Parameters
The following values may be logged and/or displayed on the Dashboard while tuning. The parameters used by the Dashboard and Datalogging can be adjusted independently from eachother (ie: what you display on your dashboard can be different from what you datalog if you so desire).
# Engine Load
# RPM
# Relative Boost Pressure
# A/F Ratio (from factory sensor)
# A/F Ratio (from external device/wide band)
# Ignition Timing
# Advance Timing Map (Knock Correction)
# Ignition Advance Multiplier
# Injector Pulsewidth
# Engine Knock
# A/F Correction
# A/F Learning
# AVCS Advance Angle Right / Left
# Gear Position
# Alternator Duty
# Intake Air Temperature
# Mass Air Flow (g/sec)
# MAF Voltage
# Throttle Position
# Barometric Pressure
# Wastegate Duty Cycle
# Coolant Temperature
# Manifold Absolute Pressure
# Vehicle Speed
# Fuel Pump Duty Cycle
# Idle Speed Control Valve Duty Cycle
That download thing to me is still "meh"
Old 04-07-2005, 04:58 PM   #19
LotusDriftx
Member#: 48528
ha, actually no, for the one that doesn't run.
The redcar is supposed to drive away into the sunset tomorrow, so that frees up a little fun money.
Old 04-07-2005, 04:59 PM   #20
D_Block
Member#: 64127
on order
Cool, but cooler if you get the black car running first. Gosh!
Old 04-07-2005, 05:01 PM   #21
D_Block
Member#: 64127
on order
*EDIT*
Meh, your car, your money, your choice. They look pretty nice though. I guess I do have part JDM itch
Old 04-07-2005, 05:03 PM   #22
LotusDriftx
Member#: 48528
one thing the nexus gauges don't have is the ability to buy one single display and not worry about ricing out your vehicle with a gazzilion ugly purple gauges.
Old 04-07-2005, 05:07 PM   #23
D_Block
Member#: 64127
on order
Theres the hateful bob I know
Old 04-07-2005, 05:14 PM   #24
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
These are the usual suspects are was expecting in this thread.
Old 04-07-2005, 05:23 PM   #25
LotusDriftx
Member#: 48528
Actually if I could save a good 50-100 bucks on these, I would get them over the DEFI's.
But, the deal I found on the defi's is SIGNIFICANTLY cheaper than the prices I saw for the nexus gauges from a quick search just now (not to say that won't change after the NEXUS gauges have been around for a bit).
FS: Autometer Nexus Gauge Set w/ Controller and Custom WRX Gauge Pod bcbaohio Interior/Dressup/Audio & Security 2 05-20-2011 11:41 PM
Any Input on Autometer Nexus Gauges?? Eric Rule Electrical & Lighting 5 04-01-2009 01:24 AM
Nj: Autometer Nexus Gauges!! Top Of The Line!! Egt, Boost, Oil Pressure Aspen524 Private 'For Sale' Classifieds 8 04-26-2006 11:17 PM
Autometer Nexus Gauges subieworx General Community 49 02-09-2005 12:04 PM
Do any vendors sell the TXS catted misection alone? Enigma76 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-25-2003 08:51 AM
